Starting I35 Turbo Build
Old Sep 26, 2010 | 03:57 PM
  #41
InfinitiI35Rice's Avatar
okay cool I think im going to go with a 28*7*2.5 intercooler
Old Sep 26, 2010 | 04:54 PM
  #42
JAMAICANLOVRBOY's Avatar
Originally Posted by LONERANGERSR20
this will be a good look, my boy did a 6 spd swap on his i35 2 yrs now, their great lookin cars and im mad the stopped makin dem
didnt really make any sense for nissan to continue with the I35. the maxima really killed the sales of the I30/35. instead they replaced it with the G35 sedan, which causes no sales conflict between nissan and infiniti.
Old Jan 3, 2011 | 02:27 PM
  #43
Is it neccessary to do new head gaskets and head studs for 5psi?
Old Jan 3, 2011 | 06:02 PM
  #44
Quickywd01's Avatar
No.
Old Jan 3, 2011 | 08:46 PM
  #45
Thanks I did order new valve cover gaskets since there is a little oil in one of the spark plug holes.. is there any other engine parts that I should replace for the 5psi?
Im getting closer to starting my turbo build, and have intercooler and many other parts ordered already.
I installed a VAFC2 recently and that should be okay to tune for 5psi?
Im planning on ordering 380cc injectors.. or should I go with the 440cc?
Do you guys recommend Tial for a wastegate brand?
And as for the MAF... if i stayed with the stock would it be maxed out.. and would i need to recurculate the BOV to prevent stalling?
Old Jan 3, 2011 | 10:35 PM
  #46
Quickywd01's Avatar
You'll be good with the vafc2. Get these injectors: http://forums.maxima.org/5th-generat...-write-up.html You're on your way to a nice setup.
Old Jan 8, 2011 | 08:03 AM
  #47
t6378tp's Avatar
Turbo 3.5
a vafc2 is fine, 380cc or cobra injectors are fine, tial is fine, stock maf is fine, if you plan to place the bov pre maf then just let it vent or if you going to run it post maf then recirculate it. Last if you don't have a 3inch exhaust then run a open dp
Old Jan 8, 2011 | 03:36 PM
  #48
Quickywd01's Avatar
Cobra injectors will be 440cc. I've seen previous forum sales for as low as $10 per injector.
Old Jan 10, 2011 | 12:01 PM
  #49
maxam's Avatar
Old Jan 10, 2011 | 01:12 PM
  #50
D I R T Y I 3 0's Avatar
Wow this sounds sick. I'll definitely check this out time to time. Good luck with it!
Old Jan 10, 2011 | 02:50 PM
  #51
Here are some pics of the Progress!!!!!
http://i1104.photobucket.com/albums/...o/e732e016.jpg
http://i1104.photobucket.com/albums/...o/c29585df.jpg
http://i1104.photobucket.com/albums/...o/b7e742be.jpg
http://i1104.photobucket.com/albums/...o/a96edf25.jpg
http://i1104.photobucket.com/albums/...o/348b13f4.jpg
http://i1104.photobucket.com/albums/...o/3b18e2ef.jpg
http://i1104.photobucket.com/albums/...o/e0f5d674.jpg
http://i1104.photobucket.com/albums/...o/88787dee.jpg
http://i1104.photobucket.com/albums/...o/328fb152.jpg
http://i1104.photobucket.com/albums/...o/c81c42ee.jpg
http://i1104.photobucket.com/albums/...o/5f05e952.jpg
http://i1104.photobucket.com/albums/...o/b2f8dd64.jpg
Old Jan 10, 2011 | 05:25 PM
  #52
nismomaxct's Avatar
Interested to see how you run your turbo piping, especially with how you have the intercooler piping routed. Do you have your feedpipe and downpipe already made?
Old Jan 10, 2011 | 05:58 PM
  #53
t6378tp's Avatar
Turbo 3.5
Just a few suggestions
1. with a intercooler that small I will put the bumper support back on
2. re-route the intercooler piping so it's not hanging below the car and so you can get to everything for when you have boost leaks
Old Jan 10, 2011 | 07:20 PM
  #54
The bumper support is on and the piping was rerouted after I bought some new 90 degree silicone.. these pics were from 4 days ago.. ill get some new ones up asap
as for the exhaust piping its going to run along the support beam next to the engine and trans... I have headers on the car so the inlet is going to come from where the 2 headers come together.
Old Jan 11, 2011 | 04:05 AM
  #55
Unklejoe's Avatar
We are doing our builds in the exact opposite order lol
Good luck
And +1 to the Cobra injectors
Old Jan 18, 2011 | 10:16 AM
  #56
Here is the link to my photobucket album of the build.. I recently started the fabrication of the turbo manifold piping. Im back at school now so the build will continue at spring break.
http://s1104.photobucket.com/albums/h338/i35turbo/
Old Jan 18, 2011 | 08:21 PM
  #57
Unklejoe's Avatar
Will you be able to keep your fog-lights with the way you ran your intercooler piping?
mvm062
Nov 30, 2020 09:00 AM
BkGreen97
Apr 2, 2016 05:47 AM
RinconI30
Nov 10, 2015 10:55 PM
QueensMAX
Sep 15, 2015 04:14 AM
Hdnseek
Sep 9, 2015 05:55 AM
