Blown Motor??? I think
As of late ive been on about 12 psi fluctuating up to no more then 14psi... Since i've turned up boost on my stock 3.0 my oil consumption and oil leaks have become outrageous...
Last night while trying to boost the car several times, each time a tremendous amount of smoke came out of my exhaust and the car would boost but when it hit, 45000rpms it would just jump to red-line in whatever gear i boosted in.. At the time i didn't think it but i imagine that my clutch was slipping and that caused this awkward situation..
The very last time of the night i went to boost the car i loaded it at 45000 rpms and boosted and it went but immediately smoked even more than any other time and the car began to overheat and it cut off at over 100mph.. i pulled over popped my hood oil was everywhere.. After letting it cool down i poured in oil and tried to crank and the starter was fried? I attempted to push start and when it did it the car sounded horrible and didnt rev past three grand.. then cut off
Today i changed the starter did an oil change and now it has a hard start but dosent crank or spark? Im guessing the motor is doneee.. anyway agree? I checked all my codes and have the same codes i've always had..
This car is my daily so im looking to get back on the road by this coming weekend monday the latest... I wish a miracle 3.5 with 3.0 timing would pop up if not im puttin back in a 3.0 probably a dek and put my mevi on it
Built motor is the plan but all i want and need is 400fwhp... Im not going above wastegate boost if I go 3.5 and if i go 3.0 no more den 10psi..
Didn't think of that will do thanks
cams are spinning.. meaning the starter is turning the flywheel, but still no start.. maybe im not getting spark? would my spark plugs go bad all at once? would my coil packs go bad all at once?
pulled the plugs wizard... they were gray on the tip and smelled more like fuel than oil... changed them still no start... I see no oil leaks... no cracks in the motor... the cams are spinning as i crank...
Im stumped... What i believed happened was the car was leaking oil so bad while i was attempting to boost it the oil pressure got so high it spit out my dipstick and thats how the oil got all over the motor...
So I boosted the car with no oil in it... it overheated then cut off..
If you ever start making feedpipes for the 5.5 gen let me know. I have a modified PFI setup on my 5.5 gen and would like to switch to a more effecient design. Also, if you have any questions about getting things up and running let me know. You planning on changing to a return style fuel setup on the 5.5 gen?
so i've heard..
if its not sold by then we'll definately see.. but im thinking about going t3 flange this time...
Return style 100%
I think broken rings...
Only thing changed is filter on front..
If you ever start making feedpipes for the 5.5 gen let me know. I have a modified PFI setup on my 5.5 gen and would like to switch to a more effecient design. Also, if you have any questions about getting things up and running let me know. You planning on run changing to a return style fuel setup on the 5.5 gen?
AaronL
Aug 8, 2020 10:31 AM
Unclejunebug
Apr 2, 2016 05:42 AM
knight_yyz
Nov 1, 2015 01:34 PM
, like stated before a t70 is alittle big even for a 3.5 but it will be a monster on the highway
