MEVI activation with SC
Old Feb 21, 2011 | 10:36 PM
jordandalley's Avatar
This question has probably been asked a few times but I'm getting conflicting answers and I'd like to clarify with a few of the boffins in here...
My MEVI is set to activate at 5,300 rpm but when it activates, my boost drops. I figure, the MEVI feature with boost is completely useless and I would be better off just leaving it off. Anything that drops the manifold pressure during boost has got to be counter-productive right?
Your thoughts???.. ...
Old Feb 22, 2011 | 03:11 AM
t6378tp's Avatar
Turbo 3.5
your have it set too high, try with it around 48-4900rpms
but the best way to find out is put it on a dyno do a pull with it closed and another with it tied open and it the activation point where they intersec on the graph
Old Feb 22, 2011 | 03:40 AM
I still don't see how a manifold that was designed for a naturally aspirated engine can benefit a boosted one. In understanding how a mevi works, applying the same principals just doesn't make sense... As far as any boosted engine goes it seems that the shorter the intake path the better. The vq30det has a very short intake manifold. So how does lengthening it or adding more volume to compress help to achieve more power?
Old Feb 22, 2011 | 10:03 AM
Flava_24/7's Avatar
Boosted Panda
Thats weird that your loosing boosts, my boost climbs up steadily with the MEVI.
Old Feb 22, 2011 | 10:08 AM
t6378tp's Avatar
Turbo 3.5
then dyno with a usim than with a mevi and you'll see
the lid on your mevi maybe leaking under boost
Old Feb 23, 2011 | 01:49 AM
I had a thought... my boost gauge is attached to the same line as the mevi vac can and actuator. This I suppose could throw the readings off....
Old Feb 23, 2011 | 03:42 AM
t6378tp's Avatar
Turbo 3.5
seperate them
litch
123
Jan 4, 2024 07:01 PM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
BkGreen97
Apr 2, 2016 05:47 AM
lrb6805
Sep 30, 2015 08:12 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
