Clamping MAF..
Old Mar 23, 2011 | 10:12 AM
stillpimpin's Avatar
Clamping MAF..
Ive been on boost the almost 2 years and never had the maf clamped, but I wanted to see if it would make any difference doing it now.. Can someone send me a sample map of there MAF clamp so i can use as reference I would appreciate it.. Thanks
Old Mar 23, 2011 | 01:41 PM
Kevlo911's Avatar
Kevlo for President
Emanage Ultimate?
Old Mar 23, 2011 | 02:59 PM
TurboA32's Avatar
what kind of difference are you trying to see? I think the point of clamping the signal is so you can see over the max potential of the stock maf without upgrading to a z32 q45 ect....but your not going to gain any power if that's what you think
Old Mar 23, 2011 | 03:07 PM
im not looking for a power gain I was just curious.. I have a 5.5gen which I think as the same voltage as the z32.. my issue is I would be driving a/f is fine then all of a sudden spike lean, I would tap the gas and it goes back to normal...
Old Mar 23, 2011 | 05:12 PM
maxgtr2000's Avatar
KH3 by popular demand
Clamping would only stop you from seeing over a certain voltage/maxing out, sounds like your maf might be on it's way out. FWIW my maf is clamped at 3.40 volts but I'm A32.
Old Mar 24, 2011 | 02:35 PM
Unklejoe's Avatar
I was under the impression that once the MAF was maxed out, you could still tune beyond that, but there wouldn't be any compensations for temperature and humidity/pressure, as the ECU would see one constant voltage. I could be wrong.
What is the purpose of clamping the MAF?
Old Mar 25, 2011 | 12:42 AM
maxgtr2000's Avatar
From my experience it prevents your injectors from locking to fully open when the maf sees max voltage, I would hit high 9's in the afr range with 370cc, so I clamped it to hit 11. You are correct, you can still tune past the max of the maf as long as you have enough fuel for it.
Old Mar 25, 2011 | 12:47 PM
I think I just need to do the relearn procedure. if I tap the throttle to goes back to normal...
Old Mar 27, 2011 | 04:45 PM
Unklejoe's Avatar
Thanks that makes sense
Lilchikcadee
May 1, 2019 08:49 AM
ThomasofSodor
Mar 22, 2018 08:18 PM
maxima297
Sep 24, 2015 08:57 PM
followthadollar
Sep 13, 2015 09:55 AM
98nismomax
Aug 26, 2015 03:03 PM
