Help w/ JWT SC tune
Old Mar 31, 2011 | 09:29 AM
  #41
Kevlo911's Avatar
Kevlo for President
http://jimwolftechnology.com/wolfpdf...%20NISSANS.PDF
That might help as well./
Old Mar 31, 2011 | 09:46 AM
  #42
i30dvr's Avatar
yea its an orange label 22860 30p00 etc....n62. so it should be a z32 maf.
kevlo- i've seen that diagram and thats what i used for mine. my colors are different but i assume the pin positions would stay the same.
dumb question but viewed from harness side would be like standing from the driver side fender looking down at it correct?
Old Mar 31, 2011 | 10:02 AM
  #43
Kevlo911's Avatar
Kevlo for President
That is mine
Old Mar 31, 2011 | 10:20 AM
  #44
i30dvr's Avatar
yea thats exactly how mine is minus the colors being different. the white wire off the z32 maf going to a32 signal is pin b correct? i have an orange wire but it looks to be in pin a location the white, 2 black, then larger white i hook to power source
Old Mar 31, 2011 | 10:21 AM
  #45
Kevlo911's Avatar
Kevlo for President
Yes, the white wire off the Z32 goes into my A32 white wire.
Old Mar 31, 2011 | 10:39 AM
  #46
i30dvr's Avatar
damn...well then mine should be correct. i dont' know what the orange wire is in pin a bc both my grounds are black....
Old Mar 31, 2011 | 10:46 AM
  #47
Kevlo911's Avatar
Kevlo for President
IMO, the wires are in different locations:
PM this guy: http://forums.maxima.org/supercharge...iring-wtf.html
Old Mar 31, 2011 | 10:49 AM
  #48
i30dvr's Avatar
just pmed him so hopefully he remembers since he was doing it in 2009 lol
Old Mar 31, 2011 | 03:06 PM
  #49
aic96max's Avatar
Justin, why not pickup a spare z32 and pigtail from Cardana if hes willing to sell you a set? im driving up frid morning, may be able to pick it for you if anything,
Old Mar 31, 2011 | 04:04 PM
  #50
i30dvr's Avatar
ok good news...gotta spare z32 maf today with pigtail for $80. the pigtail that came with it was the one w/
white
orange
black
black w/ white stripe
i soldered the new pigtail in and installed new maf and fired right up. idled normal and revs up ok. i wanna do some pulls but some drinkin doesn't allow me to right now i will go out in the morning but i know i should be good driving around normal. it revs up fine seems a lil rich but we will see tomm morning.
Old Apr 1, 2011 | 08:04 AM
  #51
Kevlo911's Avatar
Kevlo for President
white
orange
black
Should be smooth sailing from here
Old Apr 1, 2011 | 09:40 AM
  #52
t6378tp's Avatar
Turbo 3.5
update?
Old Apr 1, 2011 | 09:56 AM
  #53
cardana24's Avatar
Blown
Originally Posted by t6378tp
update?
I am guessing it depends on how long that went on
Old Apr 1, 2011 | 10:02 AM
  #54
i30dvr's Avatar
ahahha yea just got up will find out on the way to work update here later tonight
Old Apr 1, 2011 | 07:45 PM
  #55
97_Roadrunner's Avatar
I'm about to contact JWT to reflash the ecu you sold me last summer.
I really hope the new maf will solve all your problems.
Old Apr 1, 2011 | 09:55 PM
  #56
i30dvr's Avatar
ok car runs great but still leans out..... even w/ +10 from like 5800 on up to 7000. highest i went was 6547 and it was 13.8 when i let out of it....i gotta contact jwt on monday and see whats going on b/c when i talked to Ben he wasn't very helpful and basically to me it was my problem w/ my setup etc.....
Old Apr 1, 2011 | 10:58 PM
  #57
aic96max's Avatar
dam bro... youre going to have to find a way to log the voltage. what a bishhhh
Old Apr 1, 2011 | 11:16 PM
  #58
i30dvr's Avatar
yea i know..**** sucks big time....
Old Apr 2, 2011 | 02:27 AM
  #59
aic96max's Avatar
if it wasnt for the whole 99 mission you could grab any available jwt to test, and i know you spent bucks on it, otherwise id be quick to say go with an eu ):
Old Apr 2, 2011 | 05:40 AM
  #60
t6378tp's Avatar
Turbo 3.5
safc2 will log the voltage for like 30sec or something
also try adding more fuel with the safc2
Old Apr 2, 2011 | 08:47 AM
  #61
maxgtr2000's Avatar
KH3 by popular demand
Sounds like a fuel pump issue, I would hard wire it or switch it out to check.
Old Apr 2, 2011 | 09:49 AM
  #62
i30dvr's Avatar
i will hardwire it tonight or tomm. its raining right now so thats a no go....
Old Apr 4, 2011 | 08:49 PM
  #63
i30dvr's Avatar
anyone know what ground wire to cut underneath the fuel tank cap. there are two connectors and the left one which has only 2 wires are thicker which i believe is is the power and ground for the fuel pump and the other connector has about 6 small wires misc. colors. i would take a voltmeter to it but mine is acting up.
the connector on the left are both black wires.... anyone know which to cut for the ground to hardwire the fuel pump???thanks
Old Apr 14, 2011 | 10:07 PM
  #64
i30dvr's Avatar
ok hardwired the fp and its' still leaning out....wtf.
Old Apr 15, 2011 | 12:12 AM
  #65
maxgtr2000's Avatar
So do you have a high pressure pump like a walbro, or booster pump? Fmu?
Old Apr 15, 2011 | 06:38 AM
  #66
i30dvr's Avatar
yea walbro 255
Old Apr 15, 2011 | 11:52 AM
  #67
Stillen Maxima's Avatar
Pay to Play
IMO bad ecu...gotta prove that to them. Clip a video of the AF gauge and send it.
Old Apr 15, 2011 | 05:56 PM
  #68
t6378tp's Avatar
Turbo 3.5
did you ever try putting the stock ecu back to see if the problem goes away or not
Old Apr 15, 2011 | 09:01 PM
  #69
i30dvr's Avatar
no bc its an auto ecu and has like a studder fuel cut around 5k when it try to shift
Old Apr 17, 2011 | 06:17 AM
  #70
TurboA32's Avatar
did you say your friend has the same setup if so try swapping ecu's to see if he has the same problem
Old Apr 17, 2011 | 06:21 AM
  #71
TurboA32's Avatar
that studder sounds like bad coils or something
Old Apr 24, 2011 | 04:02 PM
  #72
i30dvr's Avatar
no its def not the coils. it only happens at a certain rpm then will continue to rise to factory rev limit. its something with the auto programming i believe.
Old Apr 24, 2011 | 07:13 PM
  #73
TurboA32's Avatar
do you have codes
Old Apr 25, 2011 | 07:59 AM
  #74
i30dvr's Avatar
yea the typical o2 sensors, egr, iacv, auto trans solenoid etc....
Old Apr 25, 2011 | 09:07 PM
  #75
93altima's Avatar
Turbo 4th Gen
my boy has a auto ecu in his 5spd S/C and his dosent stutter??? is it possible that the fpr dosent hold the correct psi through past 5500k
Old Apr 25, 2011 | 11:07 PM
  #76
i30dvr's Avatar
im sure its ok because the a/f is find w/ the stock ecu.....but leans out w/ the jwt
Old Apr 26, 2011 | 06:12 AM
  #77
meximax's Avatar
SC Overspinning Swapper!!
What rise rate on fuel pressure are you seeing? Most aftermarket AFPR have a 1:1 rise rate. You should be seeing 36psi at idle, 43psi at atmosphere, then 1 psi increase in fuel pressure for every psi of boost. With my JWT ECU tuned with 550s, I was seeing more than 55 psi at/near redline with about 13psi of boost.
However, it would still lean out just a tad bit for my comfort. I don't know if my 6 year old 255 was a little tired, but a Kenne Bell Boost a Pump did the trick more me. I was bumping voltage to 16V at redline. Don't recall my fuel pressure, but it was well over 60psi at redline and kept A/F in the low 12:1 range.
On a side note, be careful increasing base fuel pressure then pulling too much fuel via SAFC and or other piggyback. Do a quick search and you will find that pulling fuel via SAFC usually increases timing as a side effect. Keep it in check since advanced timing and boost don't play well.
My $.02
Old Apr 29, 2011 | 08:01 AM
  #78
i30dvr's Avatar
my fp is set at like 36 then 43 w/ the line off. i can't see the rise rate as the fpr is under the hood and haven't been on a dyno. hell it may be a problem w/ the but doubt it...
Old Apr 29, 2011 | 08:18 AM
  #79
96sleeper's Avatar
I had a similar situation. I did all the same stuff you have done. Safc wouldnt fix it. My adjustable fpr was junk and was not rising under boost like it should. I fixed that problem and was good until the small pulley, then like meximax I added a kenne-bell bap and was good to go. Check your fpr, I bet its not rising under boost.
Old May 1, 2011 | 06:31 PM
  #80
cardana24's Avatar
Blown
Justin, my car is not boosted now but I had a similar problem on the dyno last Friday. Everything was great until 5.5k then the car wanted to lean out. No matter how much fuel I addd via VAFCII it did not change anything. I ended up having to raise my fuel pressure up to about 46 psi (at idle with vac source hooked up). This gave me enough fuel up top and I just pulled fuel via VAFCII to get everything thing where I wanted it. You may want to give that a shot, it will blow the tune you have but it may fix your problem up top. Just my .02
