Emanage Ultimate Timing At Idle 5 Degrees?!
Old Jun 4, 2011 | 04:47 PM
OC_Nooby's Avatar
Hey Guys,
I'm having issues with my Maxima and think its timing related. At idle the car shows 5 degrees of timing using the Emanage data logger. I can add about 10-12 degrees to get 15 degrees of timing at idle. Shouldn't the car be stock at 15 degrees while idling? I'm thinking there is something wrong here.
Is there a way to reset the base timing?
Old Jun 4, 2011 | 05:00 PM
Kevlo911's Avatar
Kevlo for President
Do you have a OBD scanner/reader or a consult tool? I would confirm with those first.
Whats the timing when you are revving? in the 30s-50s?
Old Jun 4, 2011 | 05:38 PM
OC_Nooby's Avatar
Depending where I rev. If it's a light rev then yes its around that area. I can confirm with a scanner tomorrow, if it has the capability.
Old Jun 5, 2011 | 11:28 PM
Unklejoe's Avatar
What does your timing look like during a WOT pull or cruising down the highway at a constant load?
Old Jun 6, 2011 | 06:54 AM
OC_Nooby's Avatar
The timing during a wot pull is correct. Goes from 15-17 degrees to 25-26 degrees at redline.
Old Jun 6, 2011 | 10:24 AM
Unklejoe's Avatar
In that case I would assume the timing at idle is also correct. My timing at idle is 17 degrees on my 5.5 gen.
I wouldn't worry about it too much though.
Old Jun 6, 2011 | 03:49 PM
OC_Nooby's Avatar
Yah, not worried. Either way I added more timing at idle . It's now at 14-15 degrees. I'll try to get a proper scanner to see what my base timing is either way.
Finkle
Sep 27, 2015 09:53 PM
FlaMark
25
Aug 28, 2015 10:15 AM
t6378tp
Aug 24, 2015 07:03 AM
Maxgig
Aug 18, 2015 09:17 PM
doobadoo
Aug 15, 2015 06:43 PM
