Alternative to bigger injectors
Old Nov 5, 2011 | 07:30 PM
streetzlegend's Avatar
So back in the day Hal and others used to run two additional injectors to provide fuel when in boost, this worked but as we know was not the most efficient setup (specially some manifolds not having even distribution).
Now, how about having direct port fuel nozzles (from a nitrous kit just without nitrous nozzles) and leaving the stock injectors in. The fuel solenoid would come on with a Boost switch at certain PSI.
I think its a pretty cool idea, considering its very simple to change out the fuel jets for more or less fuel.
What are your thoughts....
Old Nov 6, 2011 | 02:28 PM
grey99max's Avatar
LandShark has Cosworth
Thoughts? I've sprayed just fuel through a NX Shark nozzle (with the nitrous connection capped) and I saw a pretty weak spray coming out. You could try this yourself and see what you think - but even a touch of nitrous would atomize the fuel much better. Maybe a much higher fuel pressure? Or a methanol pump from Snow? Are those higher pressure pumps?
It that works, could you use this to go past fuel-cut?
Old Nov 6, 2011 | 05:59 PM
Well, instead of a nitrous fuel jet, we can use a methanol nozzle which atomizes the fluid better. Not really going to try it since I already have bigger injectors, but I just thought of it and wanted to share lol
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
