Turbo Failure, its done!
Old 01-13-2012, 01:53 PM
  #41
NiZMo1o1's Avatar
Originally Posted by aic96max
track track track... lets roll!!!! weds after work son!! you run 11s and me 13s
AGREED !
NiZMo1o1 is offline
Old 01-13-2012, 07:00 PM
  #42
streetzlegend's Avatar
Soon my friends, soon. I just finished with the manifold, drilled the TB plate for idle, tomorrow 1st thing in the morning I am driving to muffler shop and have them bend me a pipe to go into the TB. I will be tuning part throttle cruising on way there, and on way back home I will be tuning WOT.
streetzlegend is offline
Old 01-13-2012, 09:02 PM
  #43
Quickywd01's Avatar
This is getting good.
Quickywd01 is offline
Old 01-14-2012, 03:30 PM
  #44
Finally got the charge pipe hooked up, the muffler shop did not want to do it, their 90deg mandrel machine does not make such sharp turn. So I just got a 90degree coupler instead.
Drove around, still have to tune it though so cant provide any performance feedback. However during WOT, when I left off, the car stayed at WOT lol, Good thing I am mentally prepared for random crap like that, so I hit neutral and it closed.
The TB cable lever thingy (w/e you call it, what the cable pulls on) got stuck against the hood, since my mounts are bad the engine lifts up at WOT, revving with no load it did not touch because engine dosent move much. So I lifted the hood a bit, put some spacers at the mounts, I also put some rubber hoses on the rad support so the hood dosnt close all the way down, gained about an inch or almost. Hopefully it does not touch now.
Old 01-15-2012, 10:31 AM
  #45
aic96max's Avatar
man that up pipe looks good! y not take off the heat cover? so like track when? next week? lol
aic96max is offline
Old 01-15-2012, 10:43 AM
  #46
Just came back from the first tune. Feels good, torque feels more linear with a constant pull. It does not hit the hood anymore.
I learned that even with the z33 manifold the afr between banks is still different. I read on the z forum that there is no explanation. Boost was at about 13-14psi. Still needs more tuning, during spoolup from a roll it drops into the 9's afr then to 11s.
What heat cover? Might do track on Wed.
Old 01-15-2012, 11:08 AM
  #47
aic96max's Avatar
told you that frank figured that out along time ago meng , man im excited to see this at the track. let me know if you really decide to hit the track and by that i mean West Palm. so i can change my oil
aic96max is offline
Old 01-15-2012, 11:09 AM
  #48
Frank? U referring to unevenbanks?
Old 01-15-2012, 11:13 AM
  #49
aic96max's Avatar
yeah , i saw him working on a z33 and he told me he has to tune them in the high 10s bc some lean issues in other banks
aic96max is offline
Old 01-15-2012, 11:14 AM
  #50
It must be something with the heads. Good thing I can turn both banks. So I can have optimal afr on both
Old 01-15-2012, 11:17 AM
  #51
aic96max's Avatar
prob the intake and too much worl to fix $$, yeah man tuning both is sweet in deed. so hurry up , clean up the tune and let me know about weds
aic96max is offline
Old 01-15-2012, 12:27 PM
  #52
Quickywd01's Avatar
Good work!
Old 01-15-2012, 12:39 PM
  #53
2000_MAXIMA_KING's Avatar
Nice work!
2000_MAXIMA_KING is offline
litch
123
01-04-2024 07:01 PM
aw11power
10-10-2021 04:57 AM
BkGreen97
04-02-2016 05:47 AM
09maxshawn11
09-30-2015 10:28 AM
Keyno McMike
09-21-2015 07:18 AM
Quick Reply: Turbo Failure, its done!
