Best way to get coolant to my turbo
Old Feb 2, 2012 | 08:47 PM
97maximachief's Avatar
I'm building a 5.5 gen turbo. My turbo will need oil and coolant. I was thinking if I can get my coolant from the throttle body. I have the nwp spacers so it's already bypassed. Can i use that as a feed and return for the turbo?
What would be pros and cons if any?
How have others in the past ran their coolant lines?
Old Feb 3, 2012 | 04:53 PM
t6378tp's Avatar
Turbo 3.5
My buddy with a boosted b13 used his heater core lines so I don't see why this would be a issue
Old Feb 6, 2012 | 07:50 PM
Thanks for the input, is there anyone using this method to cool their turbo?
Old Feb 7, 2012 | 06:30 AM
Shift_Max's Avatar
Majority of people here run a turbo that does not require coolant.
Old Feb 10, 2012 | 12:07 PM
Maxpwer's Avatar
No turbo, no care!
I also used the heater core lines for my turbo. These are quite large and can provide more than sufficient flow for all turbos. Not sure what size coolant fittings you have, but on my turbo they are 18mm compared to most which are 12mm or 14mm. The throttle body coolant lines aren't large enough for all turbos, so check to see what you have.
Old Feb 11, 2012 | 04:54 PM
MaXtUneD's Avatar
I tapped into the coolant line before the throttle body into the turbo, then ran it back into the TB. Worked on my 3rd gen without any problems.
If you aren't sure yet, just run the oil line and figure out the coolant line later. Turbo will be fine with just oil.
Old Feb 12, 2012 | 05:45 PM
VQtHuRtY's Avatar
I tapped my water lines. Lmk if you need pics...
Old Feb 19, 2012 | 05:28 AM
@Vqthurty Pics would be nice.
Old Feb 20, 2012 | 08:04 PM
VQtHuRtY's Avatar
Sorry for the late response. Here ya go!
I cut the hoses, fitted a couple of T's and ran the lines that way.
The other end of the hoses connected to the turbo...
Old Mar 22, 2012 | 08:56 PM
Nice, looks clean too would I have to run braided lines?
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
09maxshawn11
Sep 30, 2015 10:28 AM
msellas
Sep 23, 2015 09:16 PM
