Almost ready for spring!
Old Mar 11, 2013 | 02:44 PM
mhadford's Avatar
Haven't been around for a long time, but I'm almost ready to put the old black car back on the road. Josh and others might remember I bought a huge AWIC a few years ago. Probably first guy to buy one, last guy to install. It is now actually IN the car!
^^^ old photo, just to show cooler. I'll post pics of the actual install later.
New(ish) mods include:
* Huge PWR AWIC
* Front mounted AWIC heat exchanger with 2 fans
* Bosch cobra water pump (for AWIC)
* J & S Safeguard
* 2.75" pulley
* Emanage w/ injector and ignition harnesses
* RC 440 injectors
* Custom charge pipe
* Custom CAI (modelled after Latinmax)
* Greddy BOV
* Lots of pretty, bright blue silicone hose
After tuning, I expect at LEAST 600 whp!! (just kidding!)
It actually wasn't that terribly hard to fit the big cooler - I just had to get off my lazy azz. I have a bit more futzing about and tuning to do, then prolly dyno in a month or so.
Old Mar 11, 2013 | 02:56 PM
mhadford's Avatar
One mod I forgot - a new engine. Blew up the old one by running too much boost with no cooling, poor tune then a failed MAF.
Old Mar 11, 2013 | 04:10 PM
t6378tp's Avatar
Turbo 3.5
more pics
Old Mar 11, 2013 | 06:25 PM
ranmas2004's Avatar
600whp on a stock engine??
Old Mar 11, 2013 | 07:14 PM
krazy6's Avatar
He got you!
Old Mar 12, 2013 | 03:20 PM
mhadford's Avatar
I'm actually shooting for somewhere between 350 and 375 whp. I think that might be realistic with the current mods. We shall see.
I've got one of these boost limiter valves, currently set for a max of 8 psi.
Once everything is nice, safe and stable at 8 psi, I can start cranking it up. I think the maximum boost on a 2.75" pulley is around 12 psi, so it should make good power if it doesn't blow up (again).
Old Mar 12, 2013 | 07:10 PM
ranmas2004's Avatar
Thats gonna be nice bro!!
Old Mar 13, 2013 | 11:00 PM
Max streets's Avatar
let us now if that boost limiter works thinking of getten 1.
Old Aug 20, 2013 | 05:19 PM
mhadford's Avatar
Here are more pictures:
Barrel intercooler is supported by a bracket I welded up from some scrap laying around the garage.
There's an aluminum fluid cooler in front, with a couple of fans. Fans work off a rocker switch controlling two relays: Position 1 is pump only, position two is off, position 3 is fans and pump. Normal driving is pump only. The pump is attached to a frame rail under the car.
Washer bottle moved forward about 6" to make room for CAI inside fender / bumper.
The little gizmo to the left of the BOV is a boost limiter valve from 928 Motorsports. Maximum boost pressure can be dialed in, anything from 1 to 13 psi without changing pulleys. 13 PSI is the maximum for the pulley I have on right now.
Fluid reservoir is an overflow bottle from an autoparts store. GM, I think.
Read more: http://www.cardomain.com/ride/763858...#ixzz2cYk8Y2mE
a little more info is herehttp://www.cardomain.com/ride/763858...axima/page-10/
Car has been back together for a couple of months, and running pretty well. The only thing visible with the hood closed is a little bit of blue hose.
Old Aug 21, 2013 | 05:25 PM
maxgtr2000's Avatar
KH3 by popular demand
So do you manually flip the switch for the fans? If you do I would consider a hobbs/boost activated switch.
Old Aug 22, 2013 | 02:03 PM
mhadford's Avatar
I thought about that. I even have a pressure switch I could use (left over from the Stillen t-rex pump setup). When I investigated more, turns out it's best to have pump running all the time. Keep the water cool for when it's needed.
I don't usually use the fans - only if the weather is hot, and I'm in stop and go traffic or at a stop light. The fans do make the AC work better.
Old Aug 22, 2013 | 11:08 PM
OMG Mike, after all these years, you finally got your PWR aftercooler installed....and it fits! Good job.
Have a picture near the TB?
Old Aug 23, 2013 | 12:50 PM
mhadford's Avatar
You don't want to rush these things
I can take a photo near the TB in the next day or two. What are you interested to see?
Old Aug 24, 2013 | 10:59 AM
ptatohed's Avatar
Licensed to Spell
Mike! Yes! You did it. Congrats my friend.
Old Aug 27, 2013 | 07:41 PM
Quickywd01's Avatar
This is making me reconsider trying to stuff it between the rad and valvecover. Awesome.
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
sliptap
Sep 30, 2015 05:57 AM
