tuning with E-MANAGE blue (help)
Old Nov 6, 2013 | 02:11 AM
maxam's Avatar
good day all
I have just installed EMB on my turbo A32 and need maps to use it for bace tuning
my setup :
CP pistons
JWT cams
Z32TT injectors (370CC) planing to install 550CC
ARP bolts
Z370 HGs
Rev Up oil pump
walbro 255 fuel pump
was running with SAFC-II
Old Nov 6, 2013 | 06:44 AM
maxgtr2000's Avatar
KH3 by popular demand
Do you have the injector harness, ignition harness and the map sensor? If you do I have a map you can look at. Other than that if you are self tuning you won't need it, just drive the car around, log and adjust.
Old Nov 6, 2013 | 07:24 AM
maxam's Avatar
Yes I have them all. And I have innovate wideband O2 sensor . And thanks for your help
Old Nov 6, 2013 | 07:36 AM
maxgtr2000's Avatar
P.m me your email address and I can send one.
Old Nov 6, 2013 | 10:30 AM
maxam's Avatar
Ok
Old Nov 6, 2013 | 12:54 PM
maxam's Avatar
any volunteers ????
Old Nov 7, 2013 | 06:01 AM
Max streets's Avatar
Pistons and no rods.weak link r the rods,and a greddy ultimate.u got too much going there just to tune it with that.u might need to ajdust ignition timming with those cams
Old Nov 7, 2013 | 10:00 AM
maxam's Avatar
That's what I'm doing
Old Nov 7, 2013 | 03:44 PM
maxam's Avatar
If ACTIVE light is always flashing in green , what does that mean ?
Old Nov 8, 2013 | 06:32 AM
maxgtr2000's Avatar
http://forums.maxima.org/supercharge...-e-manage.html
Old Nov 8, 2013 | 08:41 AM
maxam's Avatar
As the thread that you posted here they said it's probably working fine ,but as the thread posted in your thread they :-/ they are talking about drugs :-S
Old Nov 8, 2013 | 08:15 PM
Green light means its. On working fine it doesn't mean ur car is running right but the greddy is.
Old Nov 9, 2013 | 05:12 AM
maxam's Avatar
Here is an error code came after starting the car
Old Nov 9, 2013 | 07:28 AM
maxam's Avatar
I have solved the problem.
It was wrong maf wiring .
I switched the input and out put wires .
But an other problem came out .
I can't get my emanage online while the engine is running. It comes online only when the ignition key is on .
The interaction light keep flashing when the engine . You can see the video in the previous post .
Old Nov 9, 2013 | 01:15 PM
maxam's Avatar
damn ... I'm getting crazy here .
I have searched everywhere . I didnt find any thing helps . please help meeee
Old Nov 10, 2013 | 06:37 AM
R u running Windows xp it doesn't work on any program above that
Old Nov 10, 2013 | 11:26 AM
maxgtr2000's Avatar
It runs on Windows 7, you just have to right click the icon and select "run in compatibility mode", from there on it will start with the regular double click. It may not work with a Windows 8 machine though.
As far as the turning off issue, I would double check the power connections for the emanage.
Old Nov 10, 2013 | 12:22 PM
maxam's Avatar
Hmmmm
My SAFC was connected on the same power connection of the e manage . I have removed the SAFC to connect the wideband .I will remove the wideband .
Old Nov 10, 2013 | 12:57 PM
maxam's Avatar
Here is a video shows what the problem exactly is
Old Nov 10, 2013 | 07:32 PM
maxgtr2000's Avatar
I always start the emanage after I start the car. Try that, if that doesn't work try a different serial to usb adapter if that is what you are using.
Old Nov 11, 2013 | 01:35 AM
maxam's Avatar
the same
Old Nov 11, 2013 | 04:27 AM
maxam's Avatar
I have disconnected my wideband which was connected with the Emb . And I disconnected my EMB and connect it again . But nothing happened .
The problem comes even just by toutching the cable in the USB port of the Emb
I think it is some kind of electricity ground problem
Old Nov 15, 2013 | 09:46 AM
maxam's Avatar
I found the problem ...
The RPM wire makes the problem
I have disconnected the wire and then every thing went normal .
When I reconnect the RPM the problem coms back . I think the wire is grounded somewhere.
BTW my local tuner said you should check the jumpers sitting. But I didn't find anything about this
Old Nov 30, 2013 | 11:28 AM
maxam's Avatar
back again with good news
I bought a serial port addabter from ebay. it's STARTECH serial to USB . its working perfict with realtime display . import and export while engine running .
thanx to maxgtr2000 for his maps . at least I can drive the car with it on low RPM .
next problem : I have innovate wideband gauge and sensor with LC1 . I have installed them but I dont know how do this work . after starting the car the gauge shows only dashes . like this --- . I tried to press the button it shows sometime CAL = calipration ,
HI and LO than back to dashes .
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
BobTX10
Oct 7, 2015 08:43 AM
