What to do about idle air control valve.
Old Jan 31, 2020 | 10:05 PM
SouthFlMaxTech's Avatar
So I have a 1996 maxima that I put together some time ago (2008) it has a 2008 engine in it (3.5l) with the Pathfinder 3.5l throttle body years ago when I swapped the engine I got a adapter plate from a member here for the stock 3.0l iacv valve I relocated it in the engine bay and it worked ok.. but now I am changing everything and moving the turbo up I want to have less hoses and what not under the hood what is everyone doing these days with the stock iacv from a 4th gen? Can I use the stock 3.5l Pathfinder iacv that hangs on the bottom of the throttle body? Any help would be great!
Old Feb 12, 2020 | 09:37 AM
maxprivate's Avatar
Black Lion
Hi there,
yes, you can use the stock pathfinder IACV, I’m currently using that in my 97 with a 3.5 swap. You’ll have find the pigtail to wire that into your stock harness so it will plug in. I’m also using the stock TPS. It’s all plug and play.
or
you can hack your stock iacv harness plug so it will plug into the pathfinder iacv. Smellyfart has a video on YouTube how to do this. But honestly you’re better off finding the harness plug and wiring that in.
maxfever1987
Jan 12, 2015 10:53 AM
Will
Mar 25, 2006 11:58 AM
Fred Allen Burge
Oct 5, 2005 01:35 PM
crazydave
May 5, 2004 07:37 AM
flashover
Mar 20, 2004 09:22 PM
