Tire pressure VS load rating
Old Jun 22, 2003 | 12:24 PM
mzmtg's Avatar
Minister of Silly Walks
The OEM 215/55-15 goodyears on the Maxima had a load rating of 91H and a specified tire pressure of 32psi, correct?
My new tires are OEM size, but they have a load rating of 93W. How does this affect the proper tire pressure?
Old Jun 22, 2003 | 02:00 PM
Bulldawg's Avatar
Re: Tire pressure VS load rating
NO. Those load ratings are performed at an ASTM pressure of 35 psi for normally loaded vehicles, the pressure goes up if you have a truck and are hauling something. So all load ratings are performed at the same pressure so therefore you should change your tire pressure to accomadate a different load rating. Hope this helps!...Check www.tirerack.com and their definition of load rating to make sure I am correct. Go to tire rack and select a tire, then select specs and then click on the "max load" and it will tell you the definition.
Old Jun 22, 2003 | 03:29 PM
mzmtg's Avatar
So does that mean I need to run different pressure or not?
Old Jun 22, 2003 | 09:00 PM
Bulldawg's Avatar
Wow! I am sorry, isn't it amazing how much one little word means......You should NOT change your pressure. Leave it between 32 and 35
Old Jun 23, 2003 | 03:00 PM
Bulldawg's Avatar
does this help????
Old Jun 23, 2003 | 06:12 PM
mzmtg's Avatar
heh yeah. Thanks
DJLAX152
May 4, 2021 11:46 AM
Mar 12, 2020 12:06 AM
fastcarny
Oct 6, 2015 10:42 AM
Serotta33
Sep 17, 2015 12:14 PM
jfl330
Sep 4, 2015 01:44 PM
