hub-centric rings with stock 16's (5th gen)
Old Aug 11, 2003 | 05:19 AM
T-bone's Avatar
I attempted to remove my 18" Integrals and put on the stock 16", but I had to put the 18"s back on due to BAD wheel vibration (I only went up to 40 mph). When I was putting the 16"s on, I used the hub centric rings that were used with the integrals. It didn't seem like the 16"s were sitting flush on the hub. Should I be using the rings with the stock wheels?
Thanks,
T
Old Aug 11, 2003 | 05:35 PM
Bman's Avatar
Shouldn't the stock 16" wheels not even allow you to remount them on the hub if you still have the 18" hub rings still on there? AFAIK, you have to remove the aftermarket rings and the stock wheels should just sit on the built-in hub....
Old Aug 13, 2003 | 12:04 PM
T-bone's Avatar
That's what I was thinking, but I wanted some imput from the .org.
Matt93SE
May 24, 2019 02:58 PM
Finkle
Sep 27, 2015 09:53 PM
tcb_02_max
Sep 11, 2015 12:23 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
95Maxi
Aug 25, 2015 08:01 PM
