Need Tire Help Asap please whats the difference between 215/55/16 and 215/50/16???
Old Aug 24, 2003 | 10:28 AM
ILOVEMYSE's Avatar
I have a 3rd gen and I just bought some 4th gen wheels. Everyone is telling me to put 215/55/16 tires on them. I dont really have any money and a friend of mine has a set of 215/50/16 tires that he's going to give me for free. Will they fit and what does the middle number stand for anyway.
Old Aug 24, 2003 | 11:06 AM
drewm's Avatar
Re: Need Tire Help Asap please whats the difference between 215/55/16 and 215/50/16??
What the numbers mean:
http://maxmods.dyndns.org/index.php?MaximaTires
The tires will be okay, they will just be a little small and will throw off your speedo and make you seem like you're driving faster than you really are.
Old Aug 24, 2003 | 11:58 AM
Juki5536's Avatar
What about 235/45/17 on our stock 17" SE wheels. Stock size is 225/50/17. I still dont understand the numbers on that page, but I guess I'm half retarded.
Old Aug 24, 2003 | 05:29 PM
ILOVEMYSE's Avatar
Oh ok so the first number is the width so would a 225/55/16 fit. And what would be the pros and cons of getting a 225 instead of a 215
Old Aug 24, 2003 | 06:36 PM
Bman's Avatar
Wider tires are usually better (if for nothing else other than coolness factor) but hey, they're free tires. I'd just go for those even if they're a bit undersized. I hope they have a decent amount of tread left on them and he's not giving you baldies.
Old Aug 24, 2003 | 09:25 PM
Dysfunctional
ok the first # means how wide the tire is : like a 195 is like thin, and a 295 is this as hell, like a corvett. the second # is how much side wall there is. like a 50 is fine for a 16' rim. and the last # is the size of the rim that you are putting the tirs on, so the 16 stands for the 16' rims your putting them on.
good luck, those tires will be fine and if your getting emm for free go for it.
i hope this helps.
-Dys
Old Aug 25, 2003 | 07:51 AM
ILOVEMYSE's Avatar
Thanks guys I appreciate the help. Im going to pick them up today. Ive seen them already they arent brand new but they have about 75% tread left.
Serotta33
Sep 17, 2015 12:14 PM
chernandez1278
Sep 16, 2015 01:18 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
jfl330
Sep 4, 2015 01:44 PM
