50 lbs wheels and tires too much?
Old Aug 25, 2003 | 02:57 PM
madmax2's Avatar
I just weighed my 19's with nitto 555 tires on them . Together each of them weighed 51 lbs. This sound very scary to me. Do most 18's and above usually weigh this much.
Old Aug 25, 2003 | 03:09 PM
Zam's Avatar
Zam
Thats not so bad. My 18"s with tires weigh that much.
If I keep the Max, I'll probably upgrade with some gunmetal 19" TE-37s...
Old Aug 25, 2003 | 03:32 PM
ivelweyz
the stock 15 sawblades with tires weigh like 46lbs or so...
Old Aug 25, 2003 | 03:47 PM
I30tMikeD's Avatar
my 17's with tires weigh 52lbs each
Old Aug 25, 2003 | 05:23 PM
TheMax95's Avatar
my 17s with tires weigh 48lbs
Old Aug 26, 2003 | 02:12 AM
madmax2's Avatar
Wow, so weight wont really hurt me just the extra rotational force of the bigger rim size will right. I heard that this could hurt my 0-60 time by .2 but give same 1/4 et with higher trap speed.
Old Aug 26, 2003 | 05:45 AM
I30tMikeD's Avatar
No. Weight and rim size both effect acceleration, but weight being the bigger factor. 1lb increase in unsprung weight equals 8lbs of sprung weight.
I gained .25 in the 1/4 by shaving off 40lbs of wheel weight.
Old Aug 26, 2003 | 07:19 AM
soundmike's Avatar
Very sound, Mike
That's not so bad. OEM 17's+RE92's weigh in at about 52lbs.
My 18's+HTR weigh in at 49lbs and i can definitely feel the difference in pickup.
Old Sep 1, 2003 | 06:22 PM
Ceasars Chariot's Avatar
Old Maxima Legend
16 x 7.5
31 lbs. per rim/tire
BkGreen97
Apr 2, 2016 05:47 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
