75mph wobble continues after rebalance?
Old Sep 8, 2003 | 03:31 PM
xsnowpig's Avatar
so i've got 16x8 rims from a 93 300zx non turbo. i ran the tires that came with the rims for a while but there wasn't much tread and there was a vibration at 75 mph. when i got new skins, the wobble persisted. i got the tires rebalanced, and the wobble improved, but is definitely still there. in winter, the snow tires on my OEM rims run smoooooth.
so...
do i need to try another wheel balance? a different type of balance?
are my rims bent and all the balancing in the world won't do a dam bit of good?
am i screwed because the 300zx is a rear wheel drive car?
any opinions would help (except telling me that i was an idiot for buying used rims from a salvage yard)
Old Sep 12, 2003 | 03:33 PM
Quicksilver's Avatar
OT n00bs FTMFCSL
Have you looked at your brake rotors lately?
Old Sep 16, 2003 | 03:40 AM
SLC I30t's Avatar
the rim might be bent. If the wobble is only at certain speeds, probably bent. if the rotor is warped it should only vibrate under heavy-moderate braking.
Old Sep 16, 2003 | 07:20 PM
cardio175's Avatar
sounds like a bent rim(s). LIft the car and see it for yourself, or have your frined drive the car and follow from 7 o'clock and 5 o'clock to look at both sides.
James92SE
142
Jan 2, 2024 09:23 AM
mclasser
22
Nov 12, 2020 01:58 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
dcam0326
Sep 8, 2015 11:02 PM
