Put 350z wheels on my Max
Old Oct 31, 2003 | 03:37 PM
maximazer's Avatar
This is my 96 SE
Before
After
rear wheels are wider, I don't have any rubbing or anything else.
You can find more pics on my webpage, page # 3
Old Oct 31, 2003 | 03:49 PM
PeTeRtheEaTeR's Avatar
looks good~!
Old Oct 31, 2003 | 03:52 PM
Nismotic's Avatar
Always sunny in philly
lower that son of a _________
Old Oct 31, 2003 | 04:09 PM
maxNYC's Avatar
the wheel offset looks off as the wheels are jutting out of the wheelwells.
You might consider getting the appropriate sized tires to not throw off the speedometer/odometer readings.
I had to do the same when i purchased 17" i30 wheels for my 95 Maxima.
Old Oct 31, 2003 | 04:19 PM
meccanoble's Avatar
Sports Button FTW
wow, first time i seen those on a max. My opinion is they look good, but a little too sporty for your look. If you drop car and get a kit it would look so much better. The 5th gen 2k wheels look a little more pimpy and less sporty so they would look good on a super stock maxima. My opinion. Still a good and different look
Old Oct 31, 2003 | 04:31 PM
1FSTMAX's Avatar
Almost no gap.
Old Oct 31, 2003 | 04:35 PM
DoGGy
ewwwwwwww
boooooooooooooooooooooooo
Old Oct 31, 2003 | 07:59 PM
Max Noob's Avatar
i like...are those 18 or 17s?
Old Oct 31, 2003 | 08:24 PM
max95q's Avatar
Just sell or trade the rears for another front set and all the wheels will be the same only if you dont like it or it bothers you. I like the look of the wheels on the car. Very sporty!
Old Oct 31, 2003 | 08:29 PM
maximazer's Avatar
they are 17"s
Old Oct 31, 2003 | 08:32 PM
maximazer's Avatar
It is not stock, it looks like stock
Mods that I have
Stillen Y pipe,
Stillen B pipe,
RT Hi-Flow Cat,
Frankencar Intake
Addco RSB,
Bomz FSTB
Diamond cut clears
Chrome gauge rings
Oil pressure, Air/Fuel ratio and Battery Voltage guages
350Z Rims w/ Bridgestone Potenza RE040
And some audio stuff.
Old Oct 31, 2003 | 09:59 PM
Hugemax95's Avatar
Just wondering....but did you get those from ebay. thought I saw a set a few wks back. Whats the rear offset and how much is it sticking out?
Old Oct 31, 2003 | 10:10 PM
ivelweyz
I really don't see a HINT of sporty in those wheels. Also put the wider rim/tire on the front instead of the back...
Old Oct 31, 2003 | 10:58 PM
meccanoble's Avatar
Sports Button FTW
Mods that I have
Stillen Y pipe,
Stillen B pipe,
RT Hi-Flow Cat,
Frankencar Intake
Addco RSB,
Bomz FSTB
Diamond cut clears
Chrome gauge rings
sorry, i meant looks. REally only things u can get for that to give u the sportier look is a drop and a kit...neither which u have. But your faster than me
Old Nov 1, 2003 | 10:46 AM
95nissanMax's Avatar
couldnt you put ur rear wheels in front ... since our cars are FWD?
dank4us
34
Jun 10, 2024 03:45 AM
seesole
Aug 26, 2015 11:22 AM
twotonezed
Aug 16, 2015 11:41 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
sc10692
Aug 9, 2015 09:37 AM
