Can I replace only front crap-tenzas on my 2K Max with Falken Zex ZE-512 ?
Old Dec 16, 2003 | 09:18 PM
brooklynMAX's Avatar
Old Dec 17, 2003 | 08:13 AM
defsquad222's Avatar
Tire shops suggest using the same tires on all four...but from experience with running Kumhos in the rear and 512's in the front. I'll be replacing the rear with 512's but just make sure you have enough tread on the rears and the speed rating is high enough. I havent noticed any handling issues at any speed....
Old Dec 18, 2003 | 11:22 PM
Ammi's Avatar
350 Detroit Muscle
You could even thought it's not recommended. I was too cheap to buy all 4 snow tires so I just bought 2 for the fronts.
Old Dec 19, 2003 | 09:49 AM
Ammi, buying two snow tires just for the front is highly highly unrecommended by all tire stores. Causes major traction problems on front wheel drive cars. On rear wheel drive, it is acceptable for the rears. I would remove those snow tires asap.
Old Dec 19, 2003 | 10:54 AM
Ammi's Avatar
350 Detroit Muscle
I know it's not recommended. I just did that because I was short in cash.
Balkins
Aug 12, 2015 06:39 AM
Samedi
Aug 12, 2015 01:54 AM
mls277
Aug 11, 2015 07:18 PM
jholley
Aug 11, 2015 09:38 AM
kirkhilles
Aug 8, 2015 10:53 AM
