quick question on wheel offset
Old Dec 29, 2003 | 02:43 PM
Bryan91SE's Avatar
Could someone quickly explain wheel offset to me and what an offset of 40 is on aftermarket wheels for a 4th gen maxima? Thanks.
Old Dec 29, 2003 | 06:32 PM
Bman's Avatar
http://www.tirerack.com/wheels/tech/offset.htm
What is your question? I don't get what you're asking...
Old Dec 29, 2003 | 10:08 PM
Larrio's Avatar
The Definitive AE Master
offset is relative to rim width. Its a measurement of the distance between the middle hub of the rim to the outer edge on the inside
Old Dec 30, 2003 | 06:47 PM
Bman's Avatar
No, that's backspacing.
Offset is measured from the mounting surface to the centerline of the wheel. That is why offset is universal whether you are talking about a 10" or 6" wide wheel.
Old Dec 30, 2003 | 10:50 PM
Larrio's Avatar
thanks for the correction.
Jcof88
Sep 9, 2015 03:11 PM
soloist3
29
Sep 1, 2015 03:47 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
twotonezed
Aug 16, 2015 11:41 AM
classymax420
Aug 6, 2015 06:35 PM
