Would... fit on a 2000 Maxima
Old Jan 2, 2004 | 09:02 PM
RickCardinale's Avatar
Would Mazda RX-8 rims fit on a 2000 Maxima Se?
Old Jan 3, 2004 | 06:18 AM
kwd2kSE's Avatar
What are all the specs on the wheels?
Old Jan 3, 2004 | 09:54 AM
225/45 R18
Old Jan 3, 2004 | 01:39 PM
kwd2kSE's Avatar
No, the wheel specs, not the tire specs.
Bolt pattern - example, Maxima is 5x114.3
Size - What diameter and what width
Offset - To determine if it will rub anywhere
Hub size - Maxima size is 66.1mm I believe
halfpol
Oct 17, 2022 12:16 PM
CRizz
41
Jun 7, 2021 05:42 AM
jholley
Aug 11, 2015 09:38 AM
niZ
Aug 7, 2015 10:18 PM
halfpol
Aug 5, 2015 08:24 PM
