Offset question- How do 97-99 Maxima SE rims compare to 16" S14 240 rims?
Old Jan 9, 2004 | 08:33 AM
phenryiv1's Avatar
Mod her. Ate her.
Offset question:
How do 97-99 Maxima SE rims compare to 16" S14 240 rims in terms of offset? Are they she same? Does anyone know the specs?
Old Jan 12, 2004 | 08:30 AM
phenryiv1's Avatar
Mod her. Ate her.
Update- I found out that the S14 Offest is 40mm- What is the OEM offset on the 97-99 Maxima SE rims?
Old Jan 12, 2004 | 02:37 PM
phenryiv1's Avatar
Mod her. Ate her.
More update- I THINK that the OEM offset on 97 SE rims is 45mm. It this correct?
I have 35mm offset on the max now, so I am hoping that the 35 will look okay if I move them over to a 240SX...
Old Jan 12, 2004 | 07:43 PM
nismos14's Avatar
§è~® f®ÈÄk
35 would look fine on the 240
Old Jan 13, 2004 | 07:11 AM
phenryiv1's Avatar
Mod her. Ate her.
Thanks. I will leave this info up in case someone else has the same questions.
Devo
18
Mar 7, 2016 07:36 PM
tothemax2003
Wheels/Tires
Sep 1, 2015 06:01 AM
criminalslang810
Aug 16, 2015 08:12 AM
Wolvee
Aug 11, 2015 12:24 PM
xUNIxPanther
Aug 5, 2015 09:31 AM
