Tires for 01 Maxima 17" wheels
Old Feb 16, 2004 | 02:37 PM
bigmaxxx01's Avatar
I have an 01 Maxima SE with 17" factory rims on 225/50/17 tires. A year ago, I decided to go plus-zero and bought a set of four 235/45/17's - recommended by TireRack.com. I've had no problems with the tires for a year, but now that the 2 front tires have developed buldges on the sidewalls, I am looking to replace them.
I just talked to a number of people at TireRack and NOW they tell me different things. One guy said to get 235/50/17 as a plus-zero; another said that the stock Maxima 17 inch rim cannot fit a 235 size tire because the rim is only 7 inches wide, rather than 7.5.
Has anyone gone through this before? What size tires do you have on your Max?
Old Feb 16, 2004 | 03:00 PM
housecor's Avatar
He's right - 225 is all the wider you should go on the factory 17"s. Some on the org have ignored this rule and had no problems, but you have been warned.... BTW - You'll get more responses if you post this in the tire forum.
Old Feb 16, 2004 | 03:35 PM
MaxVader's Avatar
IM runnin 235/50/17 on the stock wheel right now and had no problems what so ever.!!
Old Feb 16, 2004 | 03:51 PM
bigmaxxx01's Avatar
MaxVader, have you considered putting on 235/45/17 for a lower profile? Why did you go with a 50?
I've had no issues with my 235/435/17's, but both Tirerack and Tires.com tell me that it's "unsafe".
Old Feb 16, 2004 | 03:52 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
235/50 is within spec for a 7.0 inch wheel. ive got about 22k on my 235/50 michelin pilot a/s. i ran about 15k of them with stock wheels and now with 7.5. the 235/50 will be slighty taller and fill up a good amount of the stock wheel gap.
dank4us
34
Jun 10, 2024 03:45 AM
morteljc
Wheels/Tires
Oct 22, 2015 08:43 PM
District
Aug 15, 2015 08:23 PM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
