AP Racing Brakes: Your wheel offset?
Old Feb 17, 2004 | 09:56 AM
ardika's Avatar
For those who are running AP Racing (Stillen) brakes, what is your wheel width and offset?
I am wondering if something with 17X8.5 +42mm will clear the brakes up front.
Thank you!
Old Feb 17, 2004 | 02:01 PM
1MAX2NV's Avatar
18X8.5 with 40mm offset.
Key factors to clear AP brakes.
Rim width. It must be greater than 8"
Offset. Between 35mm to 40mm. 42 might work.
wheel design. Fat lip probably won't work. Spokes that bends out near the lip helps.
Thank you!
Old Feb 18, 2004 | 11:39 AM
ardika's Avatar
Go it!
Thanks guys! You two are really helpful. The spoke design is just like what 1MAX2NV said...no deep lips and the spokes meet close at the inner egge of the lip.
slammed95: I thought you were using the Enkeis with 17X9 with 38mm offset?
Originally Posted by slammed95
I'm using 8" wide with a 35mm offset. Clears by about 1/2".
Whether it will clear is totally dependent on spoke design.
Old Feb 18, 2004 | 06:56 PM
ardika's Avatar
slammed95,
I believe I was mistaken. I thought your RP-F1s are 17X9 in the front and 17X9.5 for the rears.....
Based on my calculation, the difference between 17X8 with 35mm offset and 17X8.5 with 42mm offset is very minimal, close to 1mm....with the 17X8 holding the advantage. So, if your wheels clear them by .5 inch....I should have plenty of room...... assuming the spoke design is good.
Thank you for your post guys!
Well my rears are 17x9, and only come in 35mm offset. They don't clear the brakes so I had to use 17x8's with 35mm offset.
Old Feb 19, 2004 | 08:24 AM
1MAX2NV's Avatar
WOW...that's interesting. Same offset but the wider rim didn't clear. Are the 17X9's lip bigger than 17X8?
RinconI30
Jun 11, 2016 08:25 PM
RinconI30
Nov 10, 2015 10:55 PM
Y2kMaxima
Wheels/Tires
Sep 14, 2015 10:56 PM
MplsMadMan
Sep 11, 2015 07:54 AM
I<3 A32's
Sep 10, 2015 11:07 AM
