18 x 7.5 = what tires?
Old Feb 21, 2004 | 07:02 AM
MaxGR97's Avatar
RIght now im looking at 18" exel radius's and are 18 x 7.5, and i am just wondering what tires would fit them? Im looking now at 225/40/18s but not sure if it is right (dont know a whole lot about tires and rims) also what is our bolt pattern? they have 4x100, 4x114.3, 5x100, and 5x114.3 Please respond, thanks
Old Feb 21, 2004 | 08:50 AM
ThurzNite's Avatar
7.5" on 18" is kinda skinny. I wouldn't go wider than 225 for fear of rolling the lip in a hard turn. 18x8 would be better so u can run 235 safely. 5x114.3. Got pics of the rims?
Jae
Old Feb 21, 2004 | 10:40 AM
MaxGR97's Avatar
http://www.wheelmax.com/Wheels/exel/exel.htm they are the 33rd ones down (exel radius gunmetal) So 225/40's fit good with 18x7.5? and these rims are really skinny, is that bad or good or what?
Old Feb 21, 2004 | 07:20 PM
Ammi's Avatar
350 Detroit Muscle
225s or 235s
Old Feb 21, 2004 | 07:24 PM
ThurzNite's Avatar
There's no problems w/using skinny tires. youll have better rain traction.
My bro bought Exel Ennio 18x8 and runs 235/40-18 Sumitomo HR+ on his 2k Max. I'd take a pic but he's not home and it's raining out.
Jae
Old Feb 21, 2004 | 07:43 PM
koldsimer's Avatar
Originally Posted by Ammi
225s or 235s
what I wanna know is how many people are actually running 235 40-45 18 on 7.5 rims. I'm currently running 225 40 18 parada spec 2s on enkei rpm2 7.5 rims. I would love to know whos running 235's and if they have problems or not.
Old Feb 21, 2004 | 09:19 PM
ThurzNite's Avatar
i had kumho 712 235/40-18 on 18x7.5 rota subzeros. 235 were definitely fat to the point where it was bulging with 38psi cold, about 40pis hot for the fronts (rears were fine with 36psi). I needed to put more air in the tires to make the most of the tread, but max psi was 40 I think. So from experience, I wouldn't do this again.
Since then, I've traded those rims/tires.
Jae
amendment: what's interesting is if you go with 17x7.5, 235-45-17 tires are usually ok on 7.5wide. Weird huh?
Old Feb 21, 2004 | 09:58 PM
athlon omega's Avatar
I'm currently running 235/40/18's on my Racing Hart Evolution C5s. I haven't had any problems. I frequently take hard corners and the grip is perfect. I have no problems with them.
Old Feb 21, 2004 | 11:29 PM
maxspeed96CT's Avatar
The original VQ...
dont people run 235's on 2k rims witch are 7" wide? thats what im planning to do if i dont sell my rims.
Old Feb 22, 2004 | 05:31 AM
Ammi's Avatar
350 Detroit Muscle
Yeap. Some people are running that size w/out any problems
Old Feb 22, 2004 | 06:28 PM
MaxGR97's Avatar
SO which one is better for 18x7.5...225/40/18 or 235/40/18?!?!? and whats the difference between the handling of the two?
Old Feb 22, 2004 | 06:49 PM
Ammi's Avatar
350 Detroit Muscle
You should be ok w/ 235s if you want to go w/ wider tires.
Wider tires = more grip
Old Feb 22, 2004 | 09:14 PM
HKMax's Avatar
I'm running 235 on 7.5. No problem here. There is a little bulge, but nothing serious. Tirerack does recommend 235 tires.
Old Feb 22, 2004 | 11:07 PM
KniGhtRydeR's Avatar
ive got 18x 7.5 running on 235s .. my vote for u is go for 235s. I was even considernig running it on 245, but didnt wanna spend more money. 245s arent recommended i dont think but ive seen people post on the board who run that and its fine.
Old Feb 23, 2004 | 12:12 PM
$tillenmax2k
i got 235/40's on my 18x7.5 also
Old Feb 23, 2004 | 03:16 PM
MaxGR97's Avatar
haha anyone have 225s on their 7.5s.....haha
Old Feb 23, 2004 | 05:10 PM
Lumbee1's Avatar
Discount Tires website recommends 215 and 225 for 18x8's
Old Feb 24, 2004 | 09:24 AM
wojowojo16's Avatar
I have 245x40x18 on 04 max rims...no problems but I dont race the car either..
Old Feb 25, 2004 | 11:09 PM
ThurzNite's Avatar
http://www.yokohamatire.com/pdf/AVSsportBltn.pdf
Approved Rim Width
225/40-18: 7.5-9.0
235/40-18: 8.0-9.5
Wider's not better... not in the case of rain. But you can cheat by overinflating your wide tires and shrinking the contact patch.
I've taken a ruler to measure contact patches on my 225 wide Azenis sport and find them just as wide as 235 wide Kumho ECSTA MX. The Azenis are known to have stiff sidewalls, whereas the Kumhos "give" due to their rounded edges.
Jae
Old Mar 4, 2004 | 04:58 PM
XeroX's Avatar
Hella internets
Im getting 225 40 18 Dunlop SP sport fm901
Should i get 235? BTW they are 8 inches wide with a 38mm offset...they discount tires (americas tire co.) told me NOT to get 235, he recomended 225...i dont want any rubbing AT ALL so can i get the 235s without having to worry bout rubbin?
Old Mar 7, 2004 | 02:00 PM
kingrukus's Avatar
no more maxima...
Hmm. After reading this I think I will go with 225/40/18 instead of 235/40/18 for my 18x7.5" wheels.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Garrettz459
Sep 28, 2015 02:50 PM
