Alignment after Lowering
Old Feb 22, 2004 | 05:03 PM
s3roush628's Avatar
Would the H&R's 1.5 inch drop require camber bolts on the 4th gen maxima? or just a regular alignment? Thanks guys, don't want to go ordering em if I'll never use them.
Old Feb 22, 2004 | 07:55 PM
Ammi's Avatar
350 Detroit Muscle
dont need camber kit. Just get a wheel alignment after installation
Old Feb 24, 2004 | 12:49 PM
PhillyDonut's Avatar
without a camber kit, the only thing that can be adjusted is the TOE, which you can do on your own very easily. just look it up on the internet or a Hayes repair book. with a 1.5" drop u prob don't need a camber kit, and it would be wise to adjust the toe. I have a 2" drop and need a camber kit for the front right because it is out of spec. It was at -1.3 (-.6 after camber kit), which was out the the -1 tolerance. the other side was -.8, which is okay.
look at NorthStar Manufacturing for camber kit (really an adjustable bolt).
also, the rears can not be adjusted.
pd
Old Feb 24, 2004 | 01:17 PM
Ammi's Avatar
350 Detroit Muscle
My camber was -0.7 before I got an alignment. All they did was align my toe. Not aligned toe = offcenter steering wheel?
Old Feb 24, 2004 | 05:50 PM
s3roush628's Avatar
Thx guys, I don't want to uneven tire wear with my new suspension. So i guess just a simple front alignment should take care of it.
Old Feb 25, 2004 | 05:02 AM
95Max's Avatar
Your alignment can be correct with the steering wheel off center. Take it back and have them index it correctly
Old Feb 25, 2004 | 05:45 AM
Ammi's Avatar
350 Detroit Muscle
what do you mean index it?
Old Feb 25, 2004 | 06:18 AM
XoPtOn's Avatar
okay guys, im getting my suspension done also, im gonna have eibach springs with tokico illumnas as struts and shocks...... i just bought rims like a month ago and i need a wheel alignment, i was thinking to get it before i have the suspension done on my car because som1 said that wheel alignments dont work after you have lowered your car..... so what should i do?
Old Feb 25, 2004 | 07:00 AM
Ammi's Avatar
350 Detroit Muscle
you are suppose to get wheel alignment done after you do suspension mod; not before
Old Feb 25, 2004 | 10:53 AM
95Max's Avatar
If the index is wrong the steering wheel will be offer center even though the alignment is correct
Old Feb 25, 2004 | 11:06 AM
Ammi's Avatar
350 Detroit Muscle
Can you adjust the index at home?
Old Feb 25, 2004 | 12:35 PM
XoPtOn's Avatar
oh okay thanks
Old Feb 26, 2004 | 10:00 AM
95Max's Avatar
Nope....take it back and have it corrected
MaxLvr21
Oct 17, 2015 12:11 PM
JonBlz
Oct 5, 2015 06:02 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Garrettz459
Sep 28, 2015 02:50 PM
