HTR+ vs. HTR 45Z
Old Feb 26, 2004 | 12:57 PM
nadir_s's Avatar
vicodin ... gift of life
HTR+ vs. HTR 45Z
can anyone tell me the difference??
I ordered and installed HTR+ 2 months ago on my rear tires. Now, I ordered the HTR+ and had em installed on the front... except when I just picekd up the car and took it to work, I noticed that instead of the HTR+, they put on the HTR 45Z.
Do you think I should take it back and have em re-order the HTR+ and have those installed??
Is it worth it? I am looking at tirerack, and both price seem to be the same.. except I dont know what the 45 means. I just see HTR Z.
But, when looking at the tirerack reviews, the HTR+ beats the HTR Z in every category.
Please let me know, thanks!
Old Feb 26, 2004 | 01:05 PM
Lumbee1's Avatar
"State of the art"HTR35-55Z is a very high performance tire featuring a high-engineered directional tread, built to carry a "Z" speed rating with jointless nylon band construction. It combines two very important high performance characteristics : high-speed handling and traction on both dry and wet surfaces.
The HTR+ is high performance all season tire.
Four wide grooves provide high performance in wet condition, and prevent from hydroplaning.
In addition, cross siping allows for all-season control.
Old Feb 26, 2004 | 01:07 PM
nadir_s's Avatar
so...
keep em?
Old Feb 27, 2004 | 09:29 PM
Dave Holmes's Avatar
One looks like a summer ultra high performance, while the other is an all-season high performance. Whether to keep them or not would depend on what you need/want. Here in Louisiana, where it doesn't snow, I am running Potenza RE750's, which are summer ultra high performance. If you have to drive through any snow, I'd go with the all-season HTR+ most likely. Summer tires generally don't grip in the snow, but are excellent in the dry and wet. Also, all-season's are generally M&S rated (mud and snow), whereas summer tires aren't. So if you do any "off-roading" keep that in mind.
Check tirerack.com for reviews on both tires from people in comparable climates as yours. Then you can make a better informed decision.
Hope this helps.
Dave
Old Feb 27, 2004 | 10:05 PM
soundmike's Avatar
Very sound, Mike
I love the HTR+ compared to the RE92 - but in a years time of owning them, i've already had 2 bubble on me (e.g. on sidewall)
Old Feb 28, 2004 | 05:01 PM
bigmaxxx01's Avatar
soundmike, I have the same problem with my HTR+. Just had to replace 2 out of 4 because of buldges on the sidewall. I went with Falkens this time.
Old Feb 28, 2004 | 05:06 PM
soundmike's Avatar
Very sound, Mike
What size did you have bigmaxxx01? I have 225/40/18 and i thought it was just because it was too low a profile.
Old Feb 29, 2004 | 07:53 AM
bigmaxxx01's Avatar
I have 235/45/17... which is basically the same profile as the original equipment (just wider). So it makes me question the quality of the HTR+.
ajaffee
Mar 15, 2001 11:20 AM
ejj
Feb 25, 2001 03:33 PM
Black95Se
Dec 4, 2000 05:19 AM
Dayle97SE
Oct 28, 2000 06:13 AM
