Time for Tires..
Old Mar 9, 2004 | 11:35 AM
LovelyPearl's Avatar
Time for Tires..
Hey,
Its time for me to replace my orginal stock tires and I need
a little help.
Can anyone suggest the best tires for a 02 Max
that do not cost a arm and a leg, but are better
than the stock tires ?
Also what would be the best size, the orginals are 17's
Im am thinking about getting some bigger ones, for a
smoother ride.
Old Mar 9, 2004 | 11:46 AM
desperado_45's Avatar
Falken 512's in 225/50/17 are about $118.00 each at discount tire.
They will fit.
Old Mar 9, 2004 | 12:45 PM
Nathan's Avatar
Falkens are good tires and not too expensive either.
Old Mar 9, 2004 | 01:01 PM
maxspeed96CT's Avatar
The original VQ...
Originally Posted by LovelyPearl
Hey,
a little help.
smoother ride.
well when you say bigger than 17's you cant get bigger unless you change your rims, unless you mean wider then you can go with 235's. There is amny good tires, go to tire rack and search for what tire fits your needs.
Old Mar 9, 2004 | 06:09 PM
ClayKY's Avatar
They will fit.
I had 4 Mastercraft Avenger LSRs installed today. The treadwear rating is 360, they're quiet, ride well and best of all were only $490 installed and out the door.
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
kjlouis
Oct 3, 2015 05:29 AM
trungg86
Sep 4, 2015 04:58 AM
Wareagle92
Sep 3, 2015 07:18 PM
