Psi?
Old Mar 14, 2004 | 09:19 AM
GraveDigger611's Avatar
Psi?
what should be the psi for 235/45/17 's ?
thnx
Old Mar 14, 2004 | 10:05 AM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
it says right on the tire sidewall
Old Mar 14, 2004 | 09:07 PM
Bman's Avatar
NO! That is 100% wrong.
The number on the sidewalls is the MAXIMUM pressure that they should run. So if the tire says "45 psi" you DON'T automatically fill it right up to that. I would go and consult a tire store or the place where you bought them. I believe it has to be higher than OE tire pressure, but how much depends on things like load rating and things that I can't recall at the moment. At the least they can give you a baseline to start with and you can adjust it from there.
I don't believe that people still think you read the side of the tire for the pressure.....
Old Mar 15, 2004 | 07:28 AM
jjs's Avatar
jjs
No kidding!!!
Old Mar 15, 2004 | 08:13 AM
meanbean's Avatar
34 is recommended. check out http://maxmods.dyndns.org/index.php?TirePressure
Old Mar 15, 2004 | 09:01 AM
Nealoc187's Avatar
SLOW
I run 32 in mine, I get better traction when I run more like 40 but the ride gets too harsh for every day driving on my ground controls when I run them that high.
aw11power
Oct 10, 2021 04:57 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
cruce91
Sep 20, 2015 10:23 AM
Maxboy23
Sep 8, 2015 06:53 PM
Nismo87SE
Jan 14, 2002 02:56 AM
