Hubcentric Rings/Wheel Fitment?
Hey Guys, can someone explain what hub rings are and what they do, or just point me in the direction of this info, thanks a lot
Also, I am planning on purchasing Volk GT-C wheels in gunmetal, i plan to get 38 offset for the front and 8.5 inches wide, i want to get 9 or 9.5 inch wide rears and i wanted to know what offset to use in the rear, i am not dropped yet but i will be on tein S tech soon......
Thanks again
WHEELMAN
Thanks again
WHEELMAN
Hub rings are sometimes needed when installing aftermarket rims. The factory wheels that come with the car are machined to fit to the exact size of the hub. This centers the wheel perfectly on the hub, meaning greater wheel balance. But, with aftermarket rims, most are manufactured with a large hub space. If the hub space on the aftermarket rim is larger than the stock hub, the wheel will not be quite centered on the car. This puts stress on the wheel studs and you'll probably feel vibrations from your wheels at high speeds such as 60mph+. If you know the hub measurement of your aftermarket rim, then you buy the rings that will compensate for your factory size hub. Try DiscountTireDirect.com. That is where I bought mine. They are made out of aluminum which will last longer than most plastic hub rings.
Originally Posted by WHEELMAN_03_SE
Thanks for filling me in, do you have any advice on my other question as to what offset would be right for 9.5 inch wide rear wheels
