Will 15" wheels fit Max?
Old Mar 29, 2004 | 11:14 AM
NebrMax's Avatar
My Maxima is in need of new tires. Having shopped around locally, I've found out the stock 17" all season tires are hard to come by. So I've been thinking about my options.
Since I no longer drive the Max (wife's now). I thought of buying stock 16" wheel/tire combo off the .org and sell the 17" wheels.
Or get some 17" summer tires and buy a set of 15" steel wheels with Blizzaks from a member on this forum for winter.
My question is, will there be enough clearance for the brakes on 15" wheels?
Old Mar 29, 2004 | 11:51 AM
kratz74's Avatar
Since yours is a 2000 a 15" may fit. I have a 2k2 Max and the 15" wheels did NOT fit. Too small by a hair-the brake caliper hit the wheel. I heard the 2k and 2k1 max had smaller diameter brakes so it may fit.
Old Mar 29, 2004 | 01:52 PM
Catalyst's Avatar
I'd definitely do 16" if you can come across them. 15" would look absolutely terrible on a Maxima due to the already HUGE wheel gap. Aesthetics aside, it may be a safety issue as the car will undoubtedly handle and drive much worse with signifigantly smaller wheels/tires. Just my $.02
Old Mar 29, 2004 | 06:41 PM
NebrMax's Avatar
thanks for the help. I'd better pass on the 15" wheels to be on the safe side. I found a set of all season tires at a reasonable cost here in Omaha. BFGoodrich Traction T/A's, 225/55/17. Don't really care about the profile of the tires. Wife drives the Max now. All she wants is good traction in all weather.
dank4us
34
Jun 10, 2024 03:45 AM
Maxima_Joe
Oct 15, 2015 08:01 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
twotonezed
Aug 16, 2015 11:41 AM
