18x8.5 wheels on the max
I just ordered EVO-5's from discount tire. They ordered 18 x 8.5 wheels. I told him that ppl run 18x7.5, but he said they would be fine...
What do you guys think?
Also is $190 per wheel a good price?
thx
thx
I have a set of 18x8.5 BBS's w/+40 offset and 245/40/18's. The rear right scrapes. I shaved the inside of the fender to remedy the problem. I am sitting on Illuminas & Eibachs. It's funny that the left side cleared and I had a prob w/the right. Nissan Quality!
I was told that theyy would not rub with the 235 and that BBS couldn't guarantee that the 245 would fit.
I wanted to get as close to the stock diameter as possible so I went with the 245. I suggest that you do the same, especially if you have an auto. Also, watch your offsets.
Stock 17" wheel diameter = 25.86
235/40/18 wheel diameter = 25.4
245/40/18 wheel diameter = 25.72
I had 245/45/17's on her after the OEM's. it caused horrible torque steer. now i am running on 225/55/17. The ride is comfy and it helped with the wheel gap. i am going to lower her next week....
I almost got the EVO-S in 17", cause the roads here suck. The OEM front wheels have been bent before due to pot holes, and my bro's crazy ar$e driving. He can rent a car when he is town from now on...
Originally Posted by dba1999us
How did you shave the inside of the fender?? do you have a write-up?
I used a dremel and a cutting bit. Its a little squirrely and you have to have a steady hand. Use a sharpie to mark the line that you want to cut as this will provide guidance.
However, if you want to go the easy route, I know of this tire shop that uses a mini sawzall with a metal cutting blade and it works like a charm, a whole lot better than my dremel. It makes for an even cut. Get yourself one of these saws andgo to work.
Do you scrape and on what side?
wow thats crazy..i just got my enkeis installed yesterday and my right rear was scraping even on the small bumps!!
and it was ONLY the back right rear too..
and im only running 17x8 with a 35 offset
i thought the guy who put on my wheels/tires screwed up or something because the right side DEFLY comes out further than the left side..
theres no other fix than to shave it huh?
Your 17x8 is w/+35 is at the same point as my 18x8.5's are w/+40. You must be running a 245 on that wheel. I hear that it won't rub if you use a 235. In fact a 245 is a bit wide for that rim if that is what you are using. I used to toss 245's on my 5.0 when it had 8 inch wide wheels and really never had any problems. I was just told that the 245 is even a bit wide even for an 8.5 inch wide wheel.
However, I wouldn't go down to a 235 because the diameter is too small compared to the 17" wheels stock diameter.
[B]Just cut the fender with a dremel or a little electric saw, which actually works alot better than the dremel. I don't suggest rolling the fender.
By the way, perfect offset. You're at the limit for an 8" wheel. Toss a pic up.
i am manual..used to be auto..had a 5 spd. conversion. manual is much faster than auto imo.
stock wheels i had a long time ago..then i switched to heavy 18s with hi perf tires..now i have the sumitomos and the 17s..i like the setup i have now the most..the enkeis are like 17 lbs each..save some weight also..just the rubbing is pi$$ing me off..
Originally Posted by slammed95
If you're car is lowered, it will rub on the right rear first. It's due to the design of the parallel link on the rear suspension.
It's really no problem. I would go with the saw as it is easier. I used a dremel and a really steady hand. If I had to do it over I would have used the saw, like they do down here at Wheel Warehouse (Anaheim, CA). They charge $25 per well.
Originally Posted by DoGGy
damn thats a bad *** good deal man. tirerack got 18x8 for $240. i was just at discountires.com and i dont see ANY evo5's there. how did u order?
Mike
i have purchased wheels/tires from them before. he gave me a deal on the wheels. the tires are 340 tread pirelli's. can't remember the #'s. the package cost $1695 tax included. i thought it would be $1400, but the tires were $165 each. and i got the warranty on the tires, stems, lugs etc....they will be on her on wednesday
i dont get it. EVo5's arent listed as rims they carry. do they sell it in ur area or what? link me to that site...
Falken GR Beta 451's in 265/40/17. Perfect size, and amazing grip. Awesome tires!
Originally Posted by kwd2kSE
You're correct, the right side will rub before the left. The place it rubs is where the rear bumper meets the quarter panel. The joint has too much material, and curves in to the wheel well. Nissan could have shaved this extra material off, but with the narrow stock tires and them stuck was back inside the fender wells there is no need. I used my 4.5" grinder to smooth out the seam-back to the bolt, and then put undercoat on the ground area. The tire actually rubs on the plastic bumper material. Look close where its rubbing, you'll see what I'm talking about. By the way, I'm running Volk 18x8.5, +40 offset, with 255/40/18 Pilot Sport A/S., with Eibach-I have no fender gap in the rear. Top of tires are even with the fender lip. Mine does not rub now, even with two adults in the back seat and the trunk full of luggage.
Mike
Mike
The wheel and tire setup on your car is insane. Can you post a pic of the rear with the 265's? What is the offset of your wheels. I think that I want to switch back to 17's from my 18x8.5's. How much does the car wander with the wide tires and are there any drawbacks. I know that it will probably be a bit slower than say a 245 tire, due to the fact that there is now more friction.
Mike
Mike
I'll take some Friday and post them up. Good time while I have the back wheels off doing prelim testing for rear big brake kit, well at least bigger and a lot better than what we have now - (quiet, its a secret project!!!)
thx
thx
OMG,,they look so sweet. i wanna sleep next to them tonight. and the drive is sooo much better than stock. i have been thinking of them, since i ordered them. the max is so happy..no pics yet though...i will take some after lowering her...
Did i mention how much i love them
Originally Posted by ABS
I don't want to hijack this thread, but could you give me more feedback on these tires?
MaxLife17
Jun 27, 2019 01:37 PM
