extending wheel studs
Old May 1, 2004 | 01:02 PM
Larrio's Avatar
The Definitive AE Master
I noticed today that after getting new rims, the rear lug nuts do not thread completely onto the original wheel studs. There is about 1/4 inch of more thread needed for the wheel lug to fully encompass the stud.
first of all, is this a major concern? I know obviously i'll have to get extended studs, but I don't want my wheels falling off on the way back to school toda.
second, where do I buy wheel studs. They look like just normal looking bolts. What is the size and length that i should be looking for?
Old May 1, 2004 | 01:09 PM
BigDogJonx's Avatar
Yes it is a concer. Need to get either 50mm or 60mm studs from Courtesyparts.com Only NISMO makes the longer studs. Stock is 42mm btw.
Dixit
Old May 1, 2004 | 02:09 PM
Matt93SE's Avatar
STFU n00b!
what he said.. unfortunately, only NISMO sells studs that size.. for $8 each.
*hmmm, money making idea..*
Old May 1, 2004 | 02:33 PM
MyownNismo's Avatar
Future Camaro SS owner
how hard is it to replace the studs. Does it involve removing the hub to get off. I got 5mm spacers that I want to install.
Old May 1, 2004 | 03:04 PM
BigDogJonx's Avatar
Generally 5mm spacers dont require longer studs. But if you want to put longer studs, all it involves is removing the caliper/mounting bracket, then remove the rotor. Then basically put an old bolt on one of the studs, just enough so that it wont fall off and bang it hard and it will pop the stud right out. Move to the next stud. Then put the new ones in. And basically use the bolt to bring the stud forward until it locks into place.
Dixit
Old May 1, 2004 | 03:42 PM
Jon91SE's Avatar
Pusssseeeehhhh
My studs are from a Mazda Protege. Damn IS rims.
Old May 1, 2004 | 04:50 PM
Larrio's Avatar
thanks guys. thanks dixit for the stock stud info.
scary how i've been running this setup for 2 months already. I only have 5mm spacers in the back. The friend that sold me these rims said it won't fit in the rear without the spacers.
would it be safe to drive back to school (about 50 miles). either that or i'm going to hitch a ride back
Old May 1, 2004 | 06:14 PM
MyownNismo's Avatar
Nope I need to use longer studs cause I would only have 3 turns and they say to have 8 turns.
Old May 1, 2004 | 07:02 PM
Larrio's Avatar
is there a write up on how to take off the rear caliper? is it anything like the front caliper? search is acting up again.
Old May 1, 2004 | 07:05 PM
Matt93SE's Avatar
STFU n00b!
general theory on the bolts is that if you have a 12mm bolt (i.e. wheel stud size), then you need 12mm of length INSIDE the nut.. so at 1.25mm thread pitch, that's about 9 threads absolute minimum.
Old May 2, 2004 | 02:14 AM
CandiMan's Avatar
Say Candyman 5 times
How you figure that out? Did you go to a parts store and eye ball the OEM stud with whatever comes close to diameter but just longer? Would you happen to know the length of hte Mazda stud? This might be a cheaper option for those needing longer wheel studs.
MIKE
Old May 7, 2004 | 03:37 AM
ZIPPIN's Avatar
Mauja He Mauja
Not to be a PW, but why is that the only spacers ppl get are H&R's? aren't there other good, cheaper spacers available??
Old May 7, 2004 | 03:58 AM
BigDogJonx's Avatar
DBA1999us, reason for that is because right now H&R is the only company that makes a complete spacer kit for the Maxima when you do 10mm or more.
Dixit
Old May 7, 2004 | 08:06 AM
mitch33x's Avatar
Removing the rear caliper is basically the same as the front caliper. Just follow BigDog's instructions, remove rotor, pound out old studs with a hammer, insert new stud into mounting hole, then throw on a bunch of washers and a nut with some anti seize and rachet the nut, the stud will get pressed into the hub. Its very easy.
BTW, I have a set of Nismo studs (10) 60mm
http://www.courtesyparts.com/Merchan...Category_Code=
Courtesy says they will only fit the Maxima front axle, not sure about rear axle fitment
I paid $70 shipped for them. $55 shipped to anyone who is interested, just PM me
Old May 7, 2004 | 08:25 AM
BigDogJonx's Avatar
They will fit all 4wheels. I got the same 60mm studs from Courtesy and I got them on all 4 wheel hubs. No problem. Except the rear you have to "notch" out the dust shield a bit so you can "clear" the 60mm stud to go into the hub.
Dixit
Old May 7, 2004 | 08:35 AM
ZIPPIN's Avatar
Mauja He Mauja
Dixit
Dixit,
any pics of the end result?
Old May 7, 2004 | 09:47 AM
BigDogJonx's Avatar
It basically looks like the front, the way the front is pushed out (mainly due to clear my big brake kit) the back is the same now. Ive got a 1/2" spacer on there all the way around.
Dixit
Old May 7, 2004 | 01:21 PM
Larrio's Avatar
just pick up a set of nismo 52mm studs today for $60 bucks.
Old May 7, 2004 | 05:08 PM
ZIPPIN's Avatar
Mauja He Mauja
Dixit
any pics DIXIT??
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
Andy29
Sep 29, 2015 05:32 AM
Garrettz459
Sep 28, 2015 02:50 PM
Redfox
Sep 28, 2015 10:41 AM
