Tokico Illumina kit with 18's?
Old May 14, 2004 | 02:17 PM
nissanfreak's Avatar
I finally lowered my Maxima with the Illumina kit from custommaxima.com, and now I am in the market for some wheels. I want to go with 18's. My question is if I get bigger wheels will the wheel gap be less or more? Please post some pics if you have 18's with the Illumina kit. Thanks in advance!
Old May 14, 2004 | 02:42 PM
maximadave's Avatar
detailerdaveb@gmail.com
You will be fine. Check my homepage for pics
Old May 16, 2004 | 06:29 PM
So would the wheel gap be reduced if I go with a bigger diameter wheel such as 18s? I heard that the wheel gap increases if you go with bigger wheels is that true?
Old May 18, 2004 | 09:15 PM
ch13f's Avatar
THe gap won't actually change size if you get the proper size tire, it'll appear larger though just because you the tire is lower profile.
Old May 18, 2004 | 11:25 PM
limsandy's Avatar
Bigger wheels have nothing to do with wheel gap. If you want less wheel gap, you gotta lower your car. BTW, illumina is strut/shock only. To lower your car, you gotta put lowering springs or coil-over. 18" wheels are fine. Dont worry about it.
~limsandy
Old May 19, 2004 | 06:46 PM
Well I guess its time to hunt for some wheels!!!
Apr 16, 2020 05:15 AM
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
Pied
Sep 26, 2015 03:29 PM
