help! wheel offset question
Old Jun 6, 2004 | 11:13 PM
classyi30t's Avatar
Hi Everyone:
Can someone tell me if the SSR GT1 with the size of 18X7.5 offset 45mm 4X114.3 would fit 2001 Maxima/I30? tks in advance!!
Old Jun 7, 2004 | 12:37 AM
MIXXMAX's Avatar
Originally Posted by classyi30t
Hi Everyone:
I don't see why not. The rim will just be slightly in more to the suspension parts than the factory wheels which shouldn't harm anything. Just to note, though, aren't the Max's and I30's 5 lug, not 4 lug?
Old Jun 7, 2004 | 01:08 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Offset is fine, but you need to make sure you're looking at 5x114.3 lug wheels not 4x.
Old Jun 7, 2004 | 01:16 AM
classyi30t's Avatar
tks to you all, oops, its a typo, it should be 5x114.3...
Old Jun 7, 2004 | 01:23 AM
SEmy2K2go's Avatar
Go BUCKS!!!
Figured thats what it was. Should look good on the I30.
Old Jun 7, 2004 | 01:29 AM
cobymoby's Avatar
Will fit perfectly. Go with a 235/40/18 tire and you are good to go. Make sure to at least get hub rings for the front two wheels, all 4 would be better. Our hub is 66.1mm. The SSR hub size is 73mm. If you don't know what I'm talking about just ask your rim shop for a 73mm to 66.1mm hub ring.
Old Jun 7, 2004 | 02:31 AM
UMD_MaxSE's Avatar
Got Bent?
GT-1 come in 18x8... can you get those instead of 18x7.5?
Old Jun 7, 2004 | 05:45 AM
Ammi's Avatar
350 Detroit Muscle
You need to get at least 8" wide rims. You need to get some spacers too with that offset.
Old Jun 7, 2004 | 12:38 PM
classyi30t's Avatar
Originally Posted by slammed95
Get the 18x8 with 38mm offset. They will be much better.
Tks for all the info here, but can someone explain why 18x8 is "better" than 18x7.5 beside better handling?
Old Jun 7, 2004 | 02:46 PM
Ammi's Avatar
350 Detroit Muscle
better grip too
Old Jun 9, 2004 | 12:12 AM
uscav8r's Avatar
It all depends on what size tire you want to mount. I'd figure out what size tire you need/want, and then go from there. If you get a rim size that is closer to the middle of the tire's rim-size range, rather than on the extremes, you will have more choices available to you in the future if you want to upsize or downsize (or change profile within a particular width...)
As an example, a 245/45-18 may take a 7.5-9 inch rim, but a 245/40-18 may take a 8-9.5 inch rim. If you get the 245/45 on a 7.5 inch rim now, but then find out you have rubbing issues, you would technically be out of spec for mounting the shorter sidewalled 245/40...
Rule of thumb: the wider the rim for a given tire, the better the handling; the narrower the rim for that same tire, the better the ride.
Plenty of guys use spacers, but if you can get the same wheel with less offset, that is much better (its like a built-in spacer). Less things to get out of balance!
Old Jun 9, 2004 | 10:40 AM
VQvroom's Avatar
God, i know you didnt help me but this cleared up some of my questions about offset and tire sizing. Ill be posting questions later on about a rim package i want to put on my max i hope your around
Old Jun 9, 2004 | 08:48 PM
uscav8r's Avatar
check out the FAQ sticky under the 5th gen forum. It has a lot of great info. For wheels, look for the topics on page 5&6:
http://forums.maxima.org/showthread.php?t=36867
Posts 66-68, 71, and 79.
There's a lot of discussion of tires to mount on the stock 17x7, but the arguments are valid for any tire/wheel combo you may want to consider.
Hope this wasn't too technical!
Good luck....
The Frye
Sep 2, 2021 11:03 AM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
maximusrising
Sep 2, 2015 09:55 AM
coasterswim
Sep 2, 2015 07:43 AM
