low profiles on stock 17's
Old Jun 9, 2004 | 02:10 PM
blkmaxx's Avatar
does anyone run with kumhos or toyos on the stock 01 17 inch se wheels? if so hows the ride.
Old Jun 9, 2004 | 04:14 PM
ch13f's Avatar
If you are planning on running a tire size other than stock, your speedometer will be thrown off, and asssuming you go with a shorter sidewall the ride will be noticeably more rough. Going to something like a 225/40/17 will also make the gaps between your fender and the tire look even worse, as you'll be decreasing the overall tire diameter.
Now that I re-read your post, I'm not sure if you're even planning on changing from the stock tire size. But the two manufacturers you listed have more than one tire obviously, the answer to your question will be dependant on which specific tire someone is running.
Old Jun 9, 2004 | 04:17 PM
Ammi's Avatar
350 Detroit Muscle
don't make your wheel gap any bigger
Old Jun 9, 2004 | 04:23 PM
DAP's Avatar
DAP
The stock tires are already low profile. Any aspect ratio of 60 or less is low profile.
Old Jun 9, 2004 | 08:11 PM
Pearltt's Avatar
I have Kumho's 225/45/17 on stock chrome GLE wheels. They are a little louder but handle a lot better. I needed a stronger tire to protect my rims from getting ****ed up. Although I need a drop...BAD...I'm getting the Illumina's, but have to wait a little bit....
Old Jun 9, 2004 | 08:30 PM
blkmaxx's Avatar
i was planning on dropping the car too, kinda like the look with the stock rims.
Old Jun 10, 2004 | 06:11 PM
dcnfrost_69's Avatar
I'm currently running 245/45/17s on mine. It's wide enough thats for sure.
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
sliptap
Sep 30, 2015 05:57 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Sep 27, 2015 08:37 AM
