WHeels balanced?
Old Sep 10, 2004 | 11:59 AM
cardana24's Avatar
Blown
WHeels balanced?
ok I have new wheels and I have had them balanced twice. But I still get the same vibration from about 30-70 mph...once I get around 80 it goes away. Whenever I have had a balancing issue it has gotten worse as speed increases...this is the opposite. Does anyone have a clue what this could be?
Old Sep 10, 2004 | 02:27 PM
nick's Avatar
i have similar problem - but the weired thing is that my car vibrates one day and then the next day is much smoother, Like last week i've put hubcentric rings on my 17" rims and took the car for ride - wow !!! it was that smooth all the way up to 85mph...
But 3 days later car started to shake and drive like crap !!! right now i'm really stumped what would cause that , I know that mine tires develop flat spots overnight , but other than that everything else on the car that might cause vibration is either new or recently replaced , my bearings have 140k on them but there is no noise or any play in them . I could also be the steering rack -hmmmm.....
Nick.
Old Sep 10, 2004 | 04:15 PM
scopium
two possibilty..
you either have a bent rim...
or MOST likely
you need a hub ring
Old Sep 10, 2004 | 09:15 PM
Ammi's Avatar
350 Detroit Muscle
did you torque your wheel lugs?
Old Sep 13, 2004 | 05:06 AM
cardana24's Avatar
Blown
1st...yes I torqued my lugs
2nd...what will hub rings do? And why would I need them? The weels fit fine.
Old Sep 13, 2004 | 06:04 AM
Ammi's Avatar
350 Detroit Muscle
Aftermarket wheels are usually overbored on the backside for different car applications. Hubcentric ring is used to ensure the wheel is hub-centered when mounted. If wheel is not properly centered, you can have a steering wheel shimmy. Hope that answers your question.
Old Sep 13, 2004 | 06:05 AM
mzmtg's Avatar
Minister of Silly Walks
www.gsp9700.com
Get your wheels balanced on one of these.
Old Sep 13, 2004 | 06:27 AM
cardana24's Avatar
Blown
Thanks for the link....I already called and set something up
Originally Posted by mzmtg
www.gsp9700.com
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
Andy29
Sep 29, 2015 05:32 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Redfox
Sep 28, 2015 10:41 AM
