225/45/17 on 2002 Max stock rim?
Yes and I would recommend it. I run that size and it is just fine, and you're not limited to like 3 different kinds of crappy tires. I think it looks better, also.
And don't waste your money on crappy bridgestone potenza RE-92's.
Yup.
Consider that the 5% profile difference represents 10% of the baseline profile [of 50]. The difference in rated load for a 225/50-17 94Y vs a 225/45-17 91Y is about 9% (1477 lbs vs 1356 lbs). Close enough for a rough cut.
Essentially, the load capacity of any given tire is a function of the volume of air contained and the inflation pressure. A rough estimate of volume for quickie comparison purposes can be made from [section width]*[section height]*[mean circumference]. While it's not a linear relationship, if you give away a little volume you'll need more inflation pressure to compensate. In this specific case, approximately 10% less volume needs about 15% more inflation pressure to maintain the same load capacity.
Norm
Norm
MAXSE5SPD
08-23-2015 12:06 PM
YourLocalAsian
08-17-2015 02:33 PM
yat70458
08-03-2015 01:16 PM
