HP Evo's on a 2000 I30
Old Nov 3, 2004 | 05:00 PM
I30 Boogie's Avatar
Hey guys...I have a few questions about fitment of these wheels. I ordered a set of 18x8 HP Evo's and just UNsuccessfully tried to mount them. The front will mount but the center cap will not and the rear won't mount up at all - wont fit over the spindle on the rear rotor (does it matter that I have ABS and rotors on all 4 wheels?). I am thinking that I need to request another offset (?) (they sent me 38mm - i think). I have two questions:
1- If i stay with the 18x8's what is the correct offset? Will this fix the fitment issues?
2 - what is the widest wheel i can go with? Anyone know if I can run a staggered set up on my car (2000 Infiniti I30). Thinking I might want to try 18x9 in the rear (??)
Any help is greatly appreciated!! Thanks!
Old Nov 4, 2004 | 06:01 AM
I30 Boogie's Avatar
bump (HELP!)
Old Nov 4, 2004 | 08:55 AM
I30 Boogie's Avatar
Originally Posted by TopElement
The width and offset are fine. It's strange that the bore of the wheels is too small to fit on the rear, not usually seen on universal aftermarket wheels. You will need a spacer to fit the front center cap though.
Keep the same size all around, it makes it much easier to rotate tires.
Will a spacer correct the bore problem in the rear as well?
Old Nov 4, 2004 | 09:03 AM
I30 Boogie's Avatar
Thanks Man!! one more question...is 225/40/18 too small? In the I30 forum I was just told that I should run a 245/40/18 or at the very least a 235/40/18....
Old Nov 4, 2004 | 09:21 AM
I30 Boogie's Avatar
It should, but make sure to get hubcentric spacers. Go with 10mm. You'll also need centering rings to match the bore of the wheels.
I suggest contacting the person you got the wheels from first. These shouldn't need any extra work to be mounted.
Ok....the rear won't mount due to the dustcap. But from what you're saying centering rings should correct that problem, right?
I have heard that some people remove the dust cap entirely (or hammer it flat)....but this sounds like it may be problematic...any thoughts?
Old Nov 4, 2004 | 10:57 AM
I30 Boogie's Avatar
Thanks for all the help TE. Here is what I have concluded:
1 - i need to send all 4 wheels and tires back and request 245/40/18's
2 - make sure that they include 10mm hubcentric spacers and centering rings
3 - i'm going to go with the 18x9 in the back, so I will need to remove the dustcap in the rear
Ok....i think that about covers it.....if there are anymore thoughts please feel free to share! Thanks!
Old Nov 4, 2004 | 12:50 PM
I30 Boogie's Avatar
sorry to keep beating this dead horse...but last question.....can I run a 245/40/18 on a 18x9" wheel?
Old Nov 4, 2004 | 04:55 PM
I30 Boogie's Avatar
Yes, it will be fine. Don't let anyone tell you otherwise.
Thanks TE....beers on me if ur ever in ATL!!!
mclasser
22
Nov 12, 2020 01:58 PM
TKHanson
Nov 24, 2018 01:39 AM
RinconI30
Jun 11, 2016 08:25 PM
Need help
23
Oct 2, 2015 08:56 AM
uttadms31
Sep 30, 2015 05:24 AM
