Torque Specs for Lugs???
Old Jan 3, 2005 | 04:01 PM
PO-POMAX2K's Avatar
Planning on giving the rims a good cleaning. Anyone know what the final torque specification for the lug nuts is? Just got a torque wrench for x-mas. Thanks.
Old Jan 3, 2005 | 04:05 PM
Tek-Niq's Avatar
my rear view mirrors flap like a f-ing bird
I do mines at 150 pounds each time I put them back on.. (my 02)
Old Jan 3, 2005 | 04:15 PM
CCS2k1Max's Avatar
Don't know about the 2k2, but the 2k1's are 80 ft-lb. Check your owners manual.
Old Jan 3, 2005 | 05:07 PM
upstatemax's Avatar
75-80 lbs, 150 is way overkill... only do that if you have a compressor and impact gun at all times !!!
i dont think overkill will hurt the car.. at most it may strip a lug nut or something...
Old Jan 3, 2005 | 05:15 PM
PO-POMAX2K's Avatar
Thanks, I'm at work right now but will check the owners Manual later. I'm guessing the factory specs would apply to the aftermarket.
Old Jan 3, 2005 | 05:35 PM
rls81's Avatar
80 lbs./ft on mine (97 gxe)
Old Jan 3, 2005 | 07:04 PM
Ammi's Avatar
350 Detroit Muscle
You are almost doubling what's recommended.
Old Jan 3, 2005 | 07:12 PM
Tek-Niq's Avatar
I just don't want them falling the fuc off...
Old Jan 3, 2005 | 07:25 PM
CCS2k1Max's Avatar
I can think of two things: "cross treads" and, worst case, "broken studs" and your wheels may still fall off.
Old Jan 4, 2005 | 09:22 AM
Bman's Avatar
Yes, it applies to aftermarket wheels as well. Torque specs have more to do with the hardware (nuts, studs) than the car or wheel. You will generally find similar lug setups have similar torque specs.
Do not torque the nuts to 150 ft-lbs. Way too much and unnecessary. You might not damage anything, but to me it seems like it would put too much pre-load on them, which could be a bad thing. Also, unless you carry a large pipe around with you you're stuck if you have a flat. They are NOT going to fall off at 80 ft-lbs as long as you're doing it correctly.
Old Jan 4, 2005 | 09:29 AM
Jeff92se's Avatar
I'm needing a caw
Sure they won't fall off. You will just never be able to get them off if you get a flat. Or it will warp your rotors from overtorquing.
Old Jan 4, 2005 | 11:29 AM
BEJAY1's Avatar
Conecarver
Tek-Niq, heed the advice of everybody else. Here's what happens when you overtorque any bolt that much.
In my 4 years of performance driving I've NEVER had a lugnut come loose that was tightened to 80-90lbs. And that includes about 2500+ nuts I've torqued. (Geez, is that right. No wonder I have no time for anything)
Old Jan 4, 2005 | 02:07 PM
Tek-Niq's Avatar
that sux my man. well I haven't taken the wheels off my 04 yet but when I do I will keep in mind the 80 pound if it applies on my 04. I'll have to check to manual..... well this is why the org is here I guess huh.................... thanx TEKNIQ
jmlee44
Oct 2, 2022 02:13 PM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Quickywd01
Sep 21, 2016 09:36 PM
dcam0326
Sep 26, 2015 05:20 AM
