Offset question and tire question.
Old Jan 12, 2005 | 09:10 PM
tpduke112's Avatar
Is a 45 offset on a 18x7.5 wheel O.K. for a Maxima? Are Nankang NS2 tires a good tire? What would you recommend? Thank you alot.
Old Jan 13, 2005 | 10:10 AM
BRAN808's Avatar
You can run it, but a +45 offset wouldn't look as good as a lower offset rim. I would also suggest checking either Tirerack or 1010Tires to check up on tires. They have a section where customers have posted reviews about the tires, and Tirerack does a lot of testing on tires as well.
Old Jan 13, 2005 | 10:23 AM
1FSTMAX's Avatar
i have 48mm offset wheels on my maxima, so you should be OK with 45. Nakang tires? I dont know, sound awfully cheap to me. I run pirelli pzero nero ms.. No knock off tires for me.
Old Jan 13, 2005 | 05:14 PM
fadeaway's Avatar
Go Hokies!!
The rims I plan on putting on my car are 18x8 with 45 offset, I did some research and found they should be fine. From what someone told me the front wheels might sit in more than the rear, not sure though. And if you put the wheels on, and it looks too scrunched in, spacers can fix it. Just more $$/labor right there.
Old Jan 13, 2005 | 05:46 PM
z32drifter's Avatar
the rears will sit further under the fender.... not the fronts
MR2 T'd
Jul 9, 2021 05:06 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
I<3 A32's
Sep 10, 2015 11:07 AM
jfl330
Sep 4, 2015 01:44 PM
Johnny9595
Sep 3, 2015 05:18 AM
