wat size tires can i fit on Murano wheels?
Old Jan 22, 2005 | 12:33 PM
Jonny98max's Avatar
i am plannin on picking up some Murano Wheels for my 98 max....i was just wondering what size tires i can fit on them....
Old Jan 22, 2005 | 04:37 PM
Ant96GLE's Avatar
Check the wheels and tires forums, theres a guy, I think his S/N is DigitalTexan, he has them. If not what I would do is get the OEM wheel size for the Murano wheel (ie 18x7 or whatever) then use the tire size calculator and compare them
Old Jan 29, 2005 | 11:42 AM
Stuntin' 101's Avatar
is there a any difference in the offset, or backspacing of these rims compared to our stock ones?
Old Jan 29, 2005 | 11:48 AM
also what size tires did u wind up getting? did u find out if 245's will fit on our car with this wheel?
Old Jan 29, 2005 | 06:06 PM
biscayne's Avatar
go to tirerack.com. They've got all sort of sorting options. Such as entering your vehicle model and it will tell you what tires customers have put on that model and what reliability they've had. I bought my last set of tires from there. Got a great deal. Saved at least $150 off of anyone locally even with the mounting and balancing. Like the fact that you can get feedback from other customers on the models you're looking at. Plenty of negative feedback, so you know they're not just posting a bunch of positive stuff to sell their tires.
Old Jan 29, 2005 | 07:13 PM
DigitalTexan2u's Avatar
I put 235's on mine.
Old Jan 29, 2005 | 07:47 PM
basically, what this is coming down to, is im either gonna buy a set of factory 17" nissan maxima/alitma wheels that have decent tires on them, or buy another set of cheap 18's, and go up a tire size. i have 18's on my car now, with 235/40/18 nitto's on them. ive managed to put slight bends in all four rims with these damn nyc streets. i also had a set of Enkie's with 245/40/18 toyo's on them.. went through six of those rims.. i'd like to get either 235/45/18's, or 245/45/18's . im wondering if the 245's will fit since the offset/ or backspacing might be different with these murano rims. Also, i know the guy that started this post had written another one, and said that the fronts stick out a little bit.. im wondering if someone can tell me how much a "little bit" is..
homeyclaus
Sep 3, 2015 06:15 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
maximaham
Aug 20, 2015 10:23 AM
twotonezed
Aug 16, 2015 11:41 AM
