Is this true?
Old Feb 21, 2005 | 07:56 PM
nissan5788's Avatar
Is this true?
http://www.miata.net/garage/tirecalc.html
At the bottom of the calculator, it says "Speedometer reading with non-stock tire is 2.1% too fast. When your speedo reads 60 mph, you are actually travelling 58.8 mph"
This also means that you'll be putting 2.1% more miles on your odometer than with stock. Usually, if you get this number under 1% difference, then the effect is negligible.
Is that true re: odometer logging 2.1% more miles? I was googling for an answer to how tire sizes affect the odometer, and found a post by someone on a forum stating the above. I couldn't find a definitive answer by googling.
Old Feb 21, 2005 | 08:24 PM
upstatemax's Avatar
i would think so... your car thinks you are going faster than you are, so it will think you are traveling greater distances at once.
Old Feb 21, 2005 | 10:32 PM
lalaMAX's Avatar
but the bigger radius the slower the speedometer reads.... isn't it?like for example.... under 1000 turns of the wheel... the smaller radius of the wheel go shorter distance...
so if u run a bigger rim and bigger tire...... the meter reads slower....
Old Feb 22, 2005 | 07:20 AM
nissan5788's Avatar
Well, going from a 225/50/17 to 225/45/17, the new (45 series) tire's radius is 0.4" smaller than the stock tires. So, the speedo reads 3.4% too fast. I'm only talking about changing the tire, have no idea how changing the rim would affect things.
If it actually does affect the odo. do/can Nissan dealers recaliberate the comp. to compensate for the decrease in radius?
Old Feb 22, 2005 | 09:02 AM
upstatemax's Avatar
you can change your rims if you want with no problems, as long as a you adjust the tire size to compensate for the size difference. i have 235/45/17's on my stock rims and its really close to the factory specs.
Old Feb 22, 2005 | 10:58 AM
carnal_c30's Avatar
Former Sponsor
AAA has speedometer recalculating adjustment expo kinda things over here in CA to help you adust it, or atleast tell you by how much its off... its free for members
just use the tire calculator to figure out how much it will change your diameter by... not a big deal
TallTom
57
Oct 14, 2025 05:16 PM
litch
123
Jan 4, 2024 07:01 PM
Gingerheadman
Oct 1, 2015 05:11 PM
Sep 27, 2015 08:37 AM
