Brembo BBK didn't fit my 17" stock rim!
Old Mar 18, 2005 | 08:55 PM
samssen's Avatar
Today, I trying to put the Brembo BBK, but my 2001 maxima 17" stock rim didn't fit. The rim didn't have enough depth to put the rim backon.
Any suggestion, may 18" rim?
Old Mar 18, 2005 | 09:21 PM
Nealoc187's Avatar
SLOW
It is because your stock rims have an offset that is too high. You need to get either spacers (cheap) or new wheels (expensive). The choice I leave up to you.
Old Mar 18, 2005 | 09:37 PM
samssen's Avatar
Can you please tell me where I can get a spacer or if I buying a new wheels, what size is the offset?
Old Mar 19, 2005 | 05:25 AM
Ammi's Avatar
350 Detroit Muscle
check local auto store. See if 5mm will work. Anything bigger, you'll need to buy longer studs.
Old Mar 19, 2005 | 08:04 AM
Nealoc187's Avatar
SLOW
Like ammi said, you need to figure out how much space you need. If its less than 5mm you can just buy one of those, but if its more you will need longer wheelstuds to go along with it. I believe the H&R spacers come with longer wheelstuds.
Old Mar 21, 2005 | 09:54 AM
Galo's Avatar
Maxima Pilot
The 5mm H&R spacers do not come with new studs, they re-use the ones on the car. 15mm and larger spacers do indeed come with new studs.
Cotozic
Jun 28, 2017 08:01 PM
maxfever1987
Nov 19, 2016 08:01 PM
incubusjohnny
Nov 3, 2015 05:18 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
twotonezed
Aug 16, 2015 11:41 AM
