225/45/17 versus 235/45/17
Old Mar 30, 2005 | 01:28 PM
ja1997max's Avatar
Is there any difference I need to know about. Picking up Kuhmo Ecsta ASX in 2 weeks and the guy is pushing 235.
My current wheels are Pilot Sport 225/50/17.
Thanks a lot for any help!
Old Mar 30, 2005 | 03:06 PM
AnDyMaN's Avatar
the 235 will make the tires wider, but they will fit stock rims. i had 235/45/17 on my car and the tires were wider.
Old Mar 30, 2005 | 03:18 PM
ja1997max's Avatar
I understand that the 235 are wider, but are there any positives or negatives of wider?
Old Mar 30, 2005 | 03:36 PM
ja1997max's Avatar
Also, rims are Motegi MR7 17x7
Does this effect width choice, tire guy seems to think not...is he correct?
Old Mar 30, 2005 | 03:45 PM
NmexMAX's Avatar
dot dot dot ...
For the best performance the wheel width should be 90% of the tire width. So the 225 would be best for that particular width wheel, but 235's work well too.
On a 4th gen I would rather have 8" wide and at the very least 7.5"
Old Mar 30, 2005 | 04:54 PM
ja1997max's Avatar
Thanks! Stuck with the 7" so 225 it will be.
Old Mar 31, 2005 | 10:10 AM
NmexMAX's Avatar
dot dot dot ...
I had 225 45-17s at one point looked ok, now that I think of it the 225-50 would have been better looking.
Old Mar 31, 2005 | 10:36 AM
ja1997max's Avatar
Why do you say that? I personally like the looks of lower profile better...damn now you got me thinking!
Old Mar 31, 2005 | 09:30 PM
Broaner's Avatar
2060lbs and falling...
The 235 will look fat(and phat) on a 7" rim. I currently have a 245 on my fronts which are 8". The look is kinda cool. It gives it a really hardcore impression. But the gearing suffers a bit. 235/45 is closest to the OEM OD. The 225/45 will be a smaller OD which will improve the gearing but it will look small in the wheel well.
OEM OD= 25.66"
235/45/17 OD= 25.46"(Closest to OEM and most grip but the gearing isn't any better than stock)
225/45/17 OD= 25.1"(Best gearing out of these options)
225/50/17 OD= 26"(Fills wheel well the best)
Make your decisions from those #'s. You won't have a problem running the 235. I say go for it. And since your 5Spd I recomend it even more. You need all the grip you can get and the gearing is much better than the auto.
Old Apr 1, 2005 | 06:55 AM
CCS2k1Max's Avatar
FYI, the Kumho ASX does come in 225/50R17. The part number is 7583.
Old Apr 1, 2005 | 05:42 PM
ja1997max's Avatar
Any comments on 235/50/17 with OD of 26.3?
Or would 235/45/17 be better?
Old Apr 1, 2005 | 07:17 PM
Broaner's Avatar
You would be very slow with w 235/50/17. You shouldn't even consider that an option. That size will look even more fat than the already chunky 235/45.
Old Apr 1, 2005 | 09:29 PM
ja1997max's Avatar
Cool, thanks a lot for all the info. Very helpful in helping me make a decision!
225/50 or 235/45 will be the decision in the next week...finally will be back on the road after 8 months of storage while at school!
cstrasz
Aug 27, 2015 08:07 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
SilverBullet98
Jun 17, 2001 10:05 AM
C-Dawg
Nov 17, 2000 11:28 AM
bl513
Oct 30, 2000 02:29 PM
