255/45/17, are they too big
Old Apr 28, 2005 | 10:05 AM
O PIPE's Avatar
Hey all, from the posts I have been reading, I think I know the answer, but I want to see what the rest of you think.
Are 255/45/17 to large of a tire for 17x7 or 17x7.5 wheels????
Any oppinions/experiances???
Please post up
O
Old Apr 28, 2005 | 10:10 AM
Jeff92se's Avatar
I'm needing a caw
1) Go to the tire's website and research the recommended wheel widths for that size
2) Go see the stickies and see if that size is correct to keep the speedometer correct.
Not brain surgery here.
Old Apr 28, 2005 | 10:27 AM
steven88's Avatar
Need A Light?
Please post up
O
255 on a 7 wide rim is definitely overkill.....as for 7.5...i've seen it done before but it definitely doesn't look right and is overkill as well....
why do u want to run such wide tires? especially why do u want to run them on such narrow rims? well if u really want 255 that badly...i suggest 8.5 wide is what u need....anything below that would look weird....and the rim won't support the tire's width
D Mason
Jun 21, 2016 04:43 AM
MichMaxFan
Sep 30, 2015 09:18 AM
