Wheel Spacers???????
Old May 15, 2005 | 03:31 PM
Talyan03's Avatar
Hi everyone! I just purchased a new set of tires they are 245/40/18 and I have g35 wheels witch are 18x8 and I was wondering that spacers i can use for the back and for the front. I want my tires to stick out a bit more to have European look when you barley can put your finger between the tire and the fender. Thanks and can you run 255’s on the 18x8 wheels? That’s for the back of course.
Old May 15, 2005 | 06:12 PM
Ammi's Avatar
350 Detroit Muscle
You can use 5mm spacers without using longer studs and don't plan on running 255s on 8" wide rims
Old May 15, 2005 | 07:00 PM
Talyan03's Avatar
thanks!!!!!!!!!!!!!!!!!!!
Old May 15, 2005 | 11:14 PM
BRAN808's Avatar
G35's
I'm not sure if that's a good idea. I have G35's on my 5th gen, and when I had the stock 245/45/18's on the back I had some pretty nasty rubbing issues. I'm dropped on Tein S-Tech's, but I think even stock you'd have problems. And this is with no spacers! Bump it out 5 more mm's and that's that much less room to play with. Just my .02.
Old May 16, 2005 | 12:00 PM
Talyan03's Avatar
i have 245/40 not 45's and no problem at all
Fbana41
Aug 29, 2016 12:18 PM
Andy29
Sep 29, 2015 05:32 AM
Lowered_a33
Sep 10, 2015 09:41 PM
dcam0326
Sep 8, 2015 11:02 PM
Maxboy23
Sep 4, 2015 06:04 PM
