350z rims or g35 rims which look better please post pics!!
Old Jun 15, 2005 | 08:57 AM
  #41
maron's Avatar
I have a set of 350z 18 inchers for sale. They are not the track edition wheels but the ones that came on the performance model. The wheels are in very good condition as they were taken off the car at only 3000 miles. one of the wheels has minor curb rash but other than that in great shape. Local pickup in the NJ/NY area only. I need to move these since I don't have my Z anymore. Let me know if anyone is interested.
Old Jun 15, 2005 | 03:01 PM
  #42
marshallc's Avatar
Originally Posted by RicoSuave98
^^^^ that is the sexiest car i have seen all day
so true
Old Jun 15, 2005 | 03:06 PM
  #43
Northern Maxima's Avatar
I like the G35 rims most. Now I want some!
Old Jun 15, 2005 | 08:44 PM
  #44
Ka$hThaRipper's Avatar
Originally Posted by Minimalmaxima
Kash, these pics are with the Tockicos, right? If you still want to get lower, holla at me about the Tockicos.
yeah, that's with tokico springs -- 3 finger gap
progress springs would yield a 2 finger gap, and that's what i wanted ideally.
but 1) too much damn work to undo everything just for an extra finger of reduced gap and 2) i'd be scraping way too much with the kit
i might've done it if i didnt' get the kit....
in fact, i recommend getting the Progress springs voer the tokico springs any day of the week..
thanks for the kind words btw
Old Jun 15, 2005 | 09:25 PM
  #45
MAXRB8's Avatar
Does anyone have the g35 coupe wheels on their 4th gen? Better yet with the 300ZX BBK with 13" cobra rotors? Are spacers recquired?
Old Jun 16, 2005 | 08:43 AM
  #46
Jeff92se's Avatar
I'm needing a caw
If the wheels clear the bbk on a 3-gen, it will clear on a 4-gen. You just have to make sure they don't stick out too much due to the low offset. But lot's of guys run the G wheels on the 3,4,5 gens with no problems.
Old Jun 17, 2005 | 04:10 PM
  #47
reMaxxxK's Avatar
z wheels look wise & G35 looks elegant
Old Jun 17, 2005 | 04:12 PM
  #48
reMaxxxK's Avatar
I thinking of put those z 18" wheels on mine with stock suspension, would it be ok, anyone try it without rub?
Old Jun 20, 2005 | 06:05 PM
  #49
irish44j's Avatar
retired moderator
well...even though I'm a bit late, here you go:
G35 coupe 18's
also, here's the G35 coupe 17's (which I use for autocross and winter). I've seen these on a 4th gen, and they look really nice (and they look bigger on the 4th gen than on my 5th gen)
Old Jun 20, 2005 | 06:06 PM
  #50
irish44j's Avatar
retired moderator
oh, and the 18's look especially pretty when moving
Old Jun 20, 2005 | 06:08 PM
  #51
irish44j's Avatar
retired moderator
one more comment: the G rims can be found pretty cheap on www.g35driver.com and www.g35frenzy.com in their FS forums....I got each of my sets for under $800 or so...mint.
Old Jun 20, 2005 | 08:48 PM
  #52
j_bryan's Avatar
is there a significant weight difference between G35c 17s vs 18s?
Old Jun 21, 2005 | 05:05 AM
  #53
Minimalmaxima's Avatar
Those wheels are tight as heck man. I almost wanna send my 350 18's back and save for those wheels you got. I swear I can see what looks like the BMW checker thing on the center caps. Just my 'magination, I guess.
Old Jun 22, 2005 | 09:49 AM
  #54
tripleGmax's Avatar
irish im coming to VA to steal your car! ill leave the rack so you can still go skiing though, k?
Old Jun 22, 2005 | 12:26 PM
  #55
Hey Irish, what year maxima is that following you in the pic where your car is moving?
Old Jun 22, 2005 | 07:49 PM
  #56
irish44j's Avatar
retired moderator
That is Joel (Puppetmaster)'s 02 Max....
the rack is off at the moment anyhow...autocrossing alot, and trying to save some gas on the commute....
before tires were mounted I weighed both of them (and my stock SE 17's). My memory is a bit fuzzy, but as I recall:
SE 17's: 26.5 lbs
G35C 18's: 24 lbs
G35C 17's: 23 lbs
none of them are light, but I am more concerned about strong in this area, where we have alot of potholes. OEM rims tend to be much stronger than most aftermarket rims. Also I use my G 17's in the winter with snow tires on them
by the way, please note that even though they look almost the same, there are two different G35 17's. The coupe 17's are 17x7.5 (front) and 17x8 (rear) with a 30mm(f)/35mm(r) offset, while the G35 sedan 17's, which look almost the same, are 17x7 with a 40mm offset....
what your are seeing are these:
I replaced the Infiniti center caps with caps off of 2000 GXE maxima 16's, which I painted black and silver....
alahjahwan09
18
Sep 21, 2015 09:12 PM
0m3nc0w
Sep 11, 2015 05:21 PM
Hdnseek
Sep 9, 2015 05:55 AM
Maxima.KsA
Sep 8, 2015 11:33 PM
adamgalazka
Sep 8, 2015 01:27 PM
