spacers for rear wheels
Old Jun 1, 2005 | 06:10 AM
Minimalmaxima's Avatar
I just got some 18" 350z wheels and I was looking at the way the stock wheels on the front are out a little more. Okay, actually I measured. I had read before on the org that they were designed to have a wider wheelbase on the front. I measure about 1/2 inch more on each side on the front (total of 1 inch wider on the front than the back). The front 350's will come out exactly where I think I want them. Where can I get spacers to put the rear ones out at the same distance? Is this bad to do?
Old Jun 1, 2005 | 07:39 AM
spacers on rear wheels. where to get? & studs too
I forgot to ask too, how hard is it to get the studs out? If I get spacers back there, I'll need new studs I'm sure, right?
Old Jun 1, 2005 | 09:53 AM
goldmaxx's Avatar
Hey , I happened to see your post. Right now I'm selling some wheel spacers on EBAY (3) of them that will fit your car. I have a 99 maxima, but I never have mounted these wheel spaces. 2 spacers are brand new the third one has a defect. They are 2inch/25mm wheel spacers made of high quality pressurized aluminum. Check out ebay
Old Jun 1, 2005 | 10:10 AM
I think that two inches is going to be a bit much. I'm looking at maybe half an inch each on the back. You got anything like that?
incubusjohnny
Nov 3, 2015 05:18 PM
Huttig2009
Sep 25, 2015 03:31 PM
stromm
Aug 27, 2015 04:13 PM
twotonezed
Aug 16, 2015 11:41 AM
