Wheels/tires Sticky? G35 wheels on maximas
Old Feb 7, 2006 | 10:44 AM
  #121
tkorpus's Avatar
Originally Posted by Mungo
As far as fitment the only issue people have reported are with centercaps. I can make that work. Not sure if there is enough space for a wheel spacer but that may be an option as well.
Genuine G35 wheels also have a problem with the center caps in the rear, the dust caps get in the way. I just tapped my dust caps in with a hammer until the center caps fit properly. Perhaps it is the same for the replicas and the other guy didn't do that?
Old Feb 7, 2006 | 01:59 PM
  #122
Lumberg™'s Avatar
on this site too damn much
nah i just put my wheels on and they didn't pop out...the rears do stick out about a millimeter or two
Old Feb 7, 2006 | 02:20 PM
  #123
tkorpus's Avatar
There is a little bit of play before the caps are no longer "snapped" in, but mine wouldn't even stay on. They popped out somewhere between 1/8 and 1/4 inch.
Old Feb 8, 2006 | 06:20 PM
  #124
NoMax...yet's Avatar
From post #23
"Anyone know the part# on the 2000 GXE cap? My 97 SE and Infiniti caps are not deep enough to lock, the part #'s are 40343/5P010 and 40342/AU510 respectively."
He's asking a question and giving numbers in the same paragraph. What do the two numbers mean respectively? I see the AU510 caps floating around but not the 5P010. What do I need for my G35's on a 4th gen?
Thanks, just don't want to waste my $$ on the wrong caps.
James
Old Feb 10, 2006 | 07:43 PM
  #125
irish44j's Avatar
retired moderator
Originally Posted by NoMax...yet
From post #23
James
the caps from any G35 wheels (17 or 18") are the same, also the small center caps from the 2000-2001 Maximas with either the 16" 5-spoke SE wheels or the 16" GXE wheels (the ones that Look like hubcaps) will work. Also, the centercaps from the Altima SE-R (and probably other Altimas) will work.
Old Feb 11, 2006 | 05:10 AM
  #126
These?
http://cgi.ebay.com/ebaymotors/Wheel...QQcmdZViewItem
They are part #40342 AU510. I haven't seen the #40343/5P010 for sale and don't know the difference.
Sorry looking for part#'s and don't know the difference.
Old Feb 11, 2006 | 12:02 PM
  #127
daves04smoke's Avatar
The "Other" project
quick question, has anyone researched about the 06 g35 sedan rims yet? I believe they are 18" and look like to 19" coupe wheels. Does anyone know?
Old Feb 11, 2006 | 12:45 PM
  #128
Mungo's Avatar
Well I got the replicas on today. I needed to put what worked out to be about a 6mm spacer (1/4 inch) backs are perfectly flush with fender and I love them. On the backs I did have to bang the sides of the dust cap in. No biggy.
Front was a little different. The end of the axle(not sure of the name) sticks out and that was pushing the center cap out. The fronts without the spacer would be perfect but I need the spacer to have a center cap.
Here is what I am think about doing and would really appreciate feedback if this is wise. There is atleast 3/8 of inch at end of the axle but beyond the pin. I am thinking I can just hacksaw 1/4 inch off and then the fronts will sit perfect? Will this work?
Now a front drop is a must!
Old Feb 11, 2006 | 03:39 PM
  #129
irish44j's Avatar
retired moderator
you could also dremel out the back of the center cap...they are THICK plastic...you can shave down some of the material. I did this on mine and it clicks on completely now.
Old Feb 11, 2006 | 05:02 PM
  #130
wesnine's Avatar
Makers Mark
Yes, wesnine did reply as to why they didn't fit. My apologies as it must not have been in this forum. The axles stuck out too far for the center caps to fit (on the FRONT, not the back). It wasn't even close, btw. They then sent spacers which were not hubcentric. The wheels, FIT (the bolt pattern was correct). However, the 30mm offset is too small. Apparently irish44 and cutler have pounded the cap in (in the rear) so perhaps they can shed some light, but as far as my situation, I would not suggest anyone going this route.
Thanks.
Old Feb 11, 2006 | 05:05 PM
  #131
wesnine's Avatar
Makers Mark
Thank-you, I told you all I wasn't crazy. I wasn't about to go and hack off my axle. GL
Old Feb 12, 2006 | 02:01 PM
  #132
Just spent 30 minutes with the Dremel. Ground down the backs, hacked off the emblem plastic rivet, then hot glued the emblems back on. Cheap and I know they fit.
Old Feb 12, 2006 | 05:14 PM
  #133
Mungo's Avatar
I took another route. I hacksawed about 1/4 inch off the front hub. Left a about 1/8 inch before the codder pin. This allowed me to mount the fronts without any wheelspacer. The fronts now sit perfectly flush with the fenders and no issue with center caps. The back is nice and flush with the 5mm spacer. Took about 15 min on each hub and a couple of blades. Very happy with the look. The 18 inches of snow today is another story...
Old Feb 12, 2006 | 06:49 PM
  #134
wesnine's Avatar
Makers Mark
Nice, any pics?
Old Feb 13, 2006 | 04:36 AM
  #135
Mungo's Avatar
yeah, I have pics but need to host them online. Will look for a place today. I know there is one listed in the faqs I think. I also know it needs a drop as the 18's only exaggerate the front biased rake.
Old Feb 13, 2006 | 11:21 AM
  #136
kcowden's Avatar
Are your wheels out of track now... with the 5mm spacer on the rear and no spacer on the front what kind of effect does that have???
Old Feb 13, 2006 | 11:24 AM
  #137
Mungo's Avatar
Didnt have any that I could tell of this morning driving to work. Not sure that 5mm would make a difference?
Old Feb 13, 2006 | 11:33 AM
  #138
kcowden's Avatar
Any rubbing or vibration issues? How fast did you get up to?
Old Feb 14, 2006 | 05:04 AM
  #139
Mungo's Avatar
No rubbing issues whatsoever, forward or reverse. I've been up to around 60 so far. Havent made it onto the highway yet.
According to the offset chart, I have more inside clearance with these rims than I did with my stockers and the tire diameter/high didnt change but fractionally. So far, I couldnt be happier.
Old Feb 14, 2006 | 05:16 AM
  #140
kcowden's Avatar
Glad to hear that your happy with them. You'll have to post pics and give it a good run on the highway. I'm curious about highway speeds and vibration. Thanks...
Old Feb 14, 2006 | 05:18 AM
  #141
Mungo's Avatar
Just curious, are you thinking that because the front the rears have essentially different offsets that this would cause some sort of vibration?
Old Feb 14, 2006 | 07:20 AM
  #142
kcowden's Avatar
Somewhat, but if the tires are balanced and the car is aligned then it shouldnt be an issue.... I guess I'm thinking to much.... Where did you get the spacers from and who made them?
Old Feb 14, 2006 | 09:24 AM
  #143
Mungo's Avatar
I just bought them down the street from a friend's garage at this large auto everything aftermarket store. I paid 5.95 per spacer and initially picked up 1/8 and 1/4 inch spacers. I didnt care what they cost at that point as I just wanted the tires mounted. I'll look to see if there was a name on them but I dont recall seeing much on them. The 1/8 were too small but the 1/4 were perfect for the rear. They sat flush with the lip of the dust cap.
As far as the replica's go, they are nice but you get what you pay for. These scratch way more easily than my neighbors real g35 coupe rims. I plan on calling the company to tell them that they need to make it clear that these wheels do no fit our Maxima's without spacers or a manual hackjob. The company did say they would send me spacers for free if the wheels didnt fit. I do like the gun metal finish on the sheer silver although I imagine some will not. To each their own.
Old Feb 14, 2006 | 06:35 PM
  #144
wesnine's Avatar
Makers Mark
Yep, well said, I agree. They seemed shocked when I said they weren't compatible with my car. Oh well, I got my money back at least. Make sure to post some pics. GL.
Old Feb 23, 2006 | 04:41 PM
  #145
GuZo's Avatar
Are you talking about the ones on my sig?
Those are the G35 sedan aero package wheels. They might be a bit hard to find though.
Simple plug and play, even centercaps fit without too much work.
No issues with them yet, and I've had a lot of compliments on them so far, only a few days since installed.
Old Feb 23, 2006 | 05:46 PM
  #146
Black92GXE's Avatar
Boomer Sooner
I'm pretty sure they are discussing the fitment of the "non OEM" wheels from ebay that are "manufactured in an OEM plant"
Old Feb 23, 2006 | 06:47 PM
  #147
The "Other" project
GuZo,
Those are exactly what I am talking about, What offset are they? Those weels look awesome on your ride!! How bad did they set you back?
Old Feb 25, 2006 | 07:28 AM
  #148
kellermax's Avatar
I've read the whole thread but i still have a question. i have a stock 2002 max, and am looking at buying some g35 18" rims, but the tire size is 245/45 all around. Would I have rubbing issues with these?
Old Feb 25, 2006 | 10:12 AM
  #149
02theMax's Avatar
Hey Dave are you looking to throw a set of these rims on your 6th gen? Maybe the 19" coupe rims will fill your fenders better.
Old Feb 25, 2006 | 10:47 AM
  #150
The "Other" project
I like the 19's better, but I may have found a set of 18's with about 2K miles for around 1200 wheels and tires..........19's have to be through the roof I'll bet
Old Feb 25, 2006 | 11:36 AM
  #151
02theMax's Avatar
I got mine for $1500CDN with tires and sensors, under 6k on rubber.
Old Feb 25, 2006 | 11:40 AM
  #152
GuZo's Avatar
GuZo,
I have no idea as to the offset. As far as the price goes, I got a good deal from a friend on these, you might have some issues trying to find them though since these are optional wheels on the sedan.
Good luck with your search.
Old Feb 25, 2006 | 07:30 PM
  #153
02theMax's Avatar
Offsets should be 33 in the rear and 30 in the front.
BTW nice car Guzo!
Old Feb 26, 2006 | 04:53 AM
  #154
The "Other" project
I don't thing the sedans are staggered like the coupe, but I may be wrong. That's kind of why I was trying to stay with a sedan wheel.
Old Feb 26, 2006 | 07:43 AM
  #155
irish44j's Avatar
retired moderator
yes. definitely.
odd that the tires are 245/45 all around. On the G35, the rears are 245/45 and the fronts are 225/45. Guy must be selling 4 rears. (btw, all the wheels are the same size/offset in the 18" size).
You want 235/40 for closest to stock diameter, or could get away with 245/45 with minimal rubbing. 245/45 in a no-go though.
Old Feb 26, 2006 | 07:45 AM
  #156
irish44j's Avatar
retired moderator
the offset is stamped into the metal on the backside of the wheel, usually on the back of one of the spokes.
I believe you are correct, though not all of the coupe wheels are staggered either (the 18x8's are not staggered, but the 17x7.5/8 are).
Old Feb 26, 2006 | 08:09 AM
  #157
The "Other" project
Thanks Irish!! Now I just have to see if I can maybe get the rims a little cheaper...........wishful thinking probably............
Old Feb 26, 2006 | 08:42 AM
  #158
02theMax's Avatar
Sorry Dave my bad, your right the sedan rims aren't staggered. I've rarely seen these style 18" g rims for sale or at all for that matter. Good luck with your search, your car will look great!
Old Feb 26, 2006 | 10:51 AM
  #159
kellermax's Avatar
Originally Posted by irish44j
yes. definitely.
thanks man, I guess ill look elsewhere then.
Old Feb 26, 2006 | 05:10 PM
  #160
irish44j's Avatar
retired moderator
you could always get new tires and re-sell the tires off those back to a G35 person on the G forums...
